XJ40 ( XJ81 ) 1986 - 1994
No brake light when ignition off
Old May 29, 2020 | 02:54 PM
Ernest Knox's Avatar
Default No brake light when ignition off
Suddenly I’ve noticed that the right side brake light on my 1988 Vanden Plas no longer works when the ignition is off. At first I thought the bulb was out, but I found that it worked when I turn the ignition on. Should the brake lights work with the ignition off? The left side does. What should I check as the problem?
My car’s steering wheel is on the left side.
Old May 29, 2020 | 05:56 PM
Update. I just checked and the right side brake lights are now working when the ignition is off. Hmmmm?
Old May 29, 2020 | 10:32 PM
Don B's Avatar
Hi Ernest,
That's a strange one. Check the wiring diagrams to see what difference there may be between power supply to the right brake lamp with the ignition off and on. You can download the Electrical Guide here:
Jaguar XJ40 Electrical Guide 1988-1989
Cheers,
Don
Old May 30, 2020 | 06:42 AM
Originally Posted by Don B
Hi Ernest,
Cheers,
Don
Thanks for the guide Don. I will check it out.
e015475
Nov 28, 2020 12:44 PM
gareth676
May 3, 2020 04:23 PM
silversurfer1221
Sep 16, 2019 04:22 PM
JaguarDaly
Apr 29, 2019 10:03 AM
sweatyfox
Jan 19, 2017 01:10 PM
