No start on my daily need help asap
Okay I have an 94 xj6 with 4.0l slant 6 with sport pack it's the square headlamp model I have a no start condition currently this is my only car .... I have replaced the distributor with a spare I just happened to have was tested good prior to installation same with the following parts, ignition amplifier, coil from 67 Camaro 5.7l (purchased new).. all fuses(new) fuel pump and fuel pump housing from 01 mercury sable (all new no modifications necessary, identical specs) new fuel pump relay and New cps(crankshaft position sensor) probably forgot a few thing just ask but anyway here are some of my crude diagnostic result
Has good injector pulse (verified with noid lights)
Has spark but is suspected weak as its orange
Petrol soaked plugs all NGK(also just replaced new)
Cps purchased new from jagbits.com 99.99us
Have Schumacher charging station for battery also good tested
Have compression
Vehicle died while driving then had no spark fixed that kinda now I'm here I'm thinking possible ecu in passenger footwell or I'm missing something can anyone help ...if I forget to include any details please ask
Have compression
Hi Larry I have nee cap and rotor on order none in the area unfortunately how ever the rotor button is 1 month old still looks great but the cap is about 6 months old so it is recent
You have a duff CPS, or the connector is hooped - if connector OK, return it. That is why your car won't start. Try putting the old one back on.
Cap and Rotor sound OK, try the CPS!
Larry
Larry
Will try agian in the morning its 11.02 PM here and let u know what happens and what do u mean hooped if u r referring to the wire being coiled over itself it is in fact NOT but I will look anyway
No - by hooped I meant no good, failed, bad, wire pushed back and not connecting etc. Sorry, common expression in my crowd
good luck tomorrow
Larry
good luck tomorrow
Larry
He means that if the crank position sensor were functioning as expected then you would see the tach register approximately 200rpms while cranking on the starter. Since you are not seeing that, then either the "new" crank sensor you installed is no good or somehow the wiring connection to the crank sensor is somehow not making the complete electrical connection.
If ether won't start it, you don't have a strong, regular spark hitting all cylinders - rotor is often the issue ...but of course you changed distributors - is you firing order ok?
One other thing I can think of, move the gear selector to "N" then try again.
Larry
Larry
CORRECT as I mentioned early I do now have spark however it is weak its orange in color and the arcs are not audible so now I need help determining if my no start is from a different reason or this one and which components should be thoroughly inspected
or replaced
Keep in mind whatever the problem may be has to
1. cause an already warm engine under load (merging onto highway I have giant led foot used to race autocross) to stall with out warning
2. Prevent restart of said engine (regardless of temp)
3. Spark is now weak when it was not b4
I do OCD check ups on lola (that's my jaguars name)
I do things like total fluid flushes, replace all bulbs and fuses when I bought her and once a year, weekly brake inspections, weekly rebalancing the tires,weekly pressure checks, daily fluid check, monthly fuel pressure checks (Lucas tried), weekly spark plug checks, 32 point inspection monthly I run a mechanic and tire shop she gets every spare second of my time (she sat in storage for 10 years 1 owner another mechanic purchase but never retitled so still one owner he tried to get it running but could not so I talked him down from 2.5k to 400 us and been driving it ever since (approximately 27k miles))
I love my jag what can I say
Jerry You're right I did say newish cap with newer newish rotor I have both on order I set that thought to the side only because it died under load while in motion then wouldn't even try to run and the possibility slim of this being the culprit however I'm not always right I don't know everything and I value and respect other owners and or mechanics as experience is far more valuable than text book knowledge so do u think a bad cap and rotor could cause this scenario and if so what might cause them to deteriorate with such speed and ferocity to cause this problem ( I like fixing things once the right way)
Not sure what happened there... I was trying to say that I had a distributor cap button get stuck up in the cap where it couldn't contact the rotor...it was newish too. Also, since we seem to be grabbing at straws, your coil is not wired backwards is it?
Coil is wired correctly and I doubt it I've took the whole ignition system apart several time in the past 4 days being very careful not to muck it up
Resistor not currently hooked up coil is sbc v8 coil tried both ways still no start...🤯
