XJ40 ( XJ81 ) 1986 - 1994
Odd Fuel Supply Problem
Old Mar 3, 2009 | 03:31 PM
grommet's Avatar
not sure how this relates to your problem but the connector block near the fuel tank on my car had a high resistance. so high that it wur all blackened. my solutiuon was to cut it off and just solder the wires together
Old Jul 3, 2009 | 01:26 AM
1988xj6navy's Avatar
Having a problem kind of like yours,but the brown wire on the relay never goes out. The fuel pump just works when it wants to I have not tired running wire yet but I am about to do the same thing you are talking about. I need to fix this its driving me crazy.
Old Jul 3, 2009 | 06:15 AM
Thermo's Avatar
Veteran: Navy
ggryder, it is possible that part of your wiring harness has suffered what is called fatigue failure. What I mean by this is the wire has been vibrating as you drive the car. This constant motion has strained the wires to the point that they have started breaking. So, what you have is a bunch of broken strands of wire still covered by the insulation that have been essentially cut. Due to this sort of event, the wires are still capable of barely touching, but when any sort of load is applied, they can't handle the load (think of it like trying to run 100 amps through 22 gauge wire).
Unfortunately, you have 2 options for this fix. 1) disassemble the wiring harness and replace the wire between the battery and relay (you can also simply run a new wire in parallel and then attach it to the wiring harness using tie straps) or, 2) replace the wiring harness all together (expensive, but will garantee no future problems with other components).
I see this sort of thing all the time with older vehicles. Sometimes you will also get water intrusion under the end of a wire and this will cause the wire to corrode inside the insulation, leading to a high resistance connection. In this case, you can cut back the wiring an inch or so to remove the high resistance point and then reattach the wire to the factory pin. But, that is a hit and miss situation.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
AL NZ
Sep 4, 2015 08:39 PM
