XJ40 ( XJ81 ) 1986 - 1994
oil leak
Old May 21, 2008 | 08:03 PM
ibjags's Avatar
Default RE: oil leak
first thing to do is find the leak
possibly as simple as cam cover gasket
then again head gasket is possible as well
oil is pretty much your discretion
me personally have always used 20/50 castrol in all of my pre 97 jags
as well as this is the oil viscosity most if not alljag dealers use on pre 97 cars both 6 and 12 cyl
Old May 21, 2008 | 10:10 PM
JagtechOhio's Avatar
Time to get back under the car, and don't worry about the head gasket. The leak from that source will be closer to the right front, dripping off the block from where the distributor is located. Your leak is on the other side of the engine.
Get a spray can of Brakleen with a straw, and clean off all around the oil filter. Make sure the filter is tight, there's nothing wrong in tightening it up a little with your oil filter wrench. Just below the filter is a "C" shaped aluminum housing. In the middle of the "C" is a 13mm locknut, which holds it onto the oil filter head. This housing is a bypass to replace the oil cooler hoses that were used on '88-'92 XJ6: it's the same oil filter head on your model, they just deleted the cooler for '93.
Once this bypass housing is clean, run the engine and recheck it. You may have to drive the car for a day... but my guess is that this is your leak source. If you remove the locknut in the center, the cover pulls off. Inside the cover are two short pipes, about an inch long. Pull the pipes out, sometimes they come out with the cover, and you'll see an "O" ring on each end of the pipe. They will be hard as a rock, and that's what's causing the leak. I think the part number is CAC 5158, you need four, coat them with vaseline and put it all together. I know you're not very experienced working on your car, but if you can get the locknut off, you can do the job. You'll lose maybe a half quart of oil when you pull it apart, so be prepared for a mess but it's not like everything is going to come out.
ibjags is correct, 20W50 is best for XJ40 in warm climates. Use 10W40 only if you live in a climate where you regularly see weather below 40 degrees F. The 20W50 turns to peanut butter below 30F.
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
