XJ40 ( XJ81 ) 1986 - 1994
Oxygen o2 Lambda Sensor
Old Sep 24, 2015 | 02:53 AM
Real Sinner's Avatar
Default Oxygen o2 Lambda Sensor
Sorry , can u help me , where to find Oxygen o2 Lambda Sensor in jaguar xj6 sovereign 4.0 , I use EPC , but still can not find where they are.
Old Sep 24, 2015 | 03:29 AM
Lawrence's Avatar
try engine management/emission systems/sensors etc
Larry
Old Sep 24, 2015 | 04:00 AM
thx , I'll write down when take a look
Old Sep 24, 2015 | 07:20 AM
And one more question, there are one or two Lambda Sensor in this model ?
Old Sep 24, 2015 | 10:07 AM
Don B's Avatar
Hi Real Sinner,
There is only one O2 sensor on the XJ40, and it is mounted on top of the exhaust pipe below the right side of the engine. The photos at the links below may be helpful:
Welcome to Jag-lovers - Members Photo Viewing Page
The manufacturer of the original O2 sensor was Bosch, and you can find the correct part number for your model year and engine here:
https://www.boschautoparts.com/auto
Regardless of which brand of sensor you buy, I highly recommend that you purchase one that already has the correct electrical connector installed. There have been many reports of problems from members who used the "Universal" type sensor that requires you to install the electrical connector that fits your car. The problem is that the sensors on the XJ40 use the tiny passages between the wiring conductors to draw fresh air into the sensor, and just the act of installing the connector improperly can cause the sensor to be non-functional.
Cheers,
Don
Old Sep 24, 2015 | 10:00 PM
O great . I find u answer very useful
mrplow58
Jan 21, 2024 05:53 AM
carl purchase
Oct 14, 2015 06:14 PM
RoyLittle0
Sep 17, 2015 01:05 PM
KarimPA
Sep 3, 2015 07:32 PM
