Panel lights
My panel lights are not working, they were working and then one day they didn't come on either with the ignition or with the side lights, any ideas where i should start?
I had an issue like this and it turned out to be a wire that was clipped and tied together again behind the kick panel on the drivers side. There is a bunch of white wires with a plug on the far right side of the kick panel if you are sitting in the drivers seat. One of those wires was the culprit. Not sure if this is the same issue you are experiencing but a good place to start since it is easy to get to.
Rkr45
Mar 23, 2015 08:16 AM
