XJ40 ( XJ81 ) 1986 - 1994
PCV valve for xj40 sovereign 1990
Old Jun 14, 2017 | 02:45 AM
BeckBeck's Avatar
Default PCV valve for xj40 sovereign 1990
Hi everyone, quick question from a noob. Where do I get a new PCV valve for this girl from? is it a standard size? PCV is one thing I have admittedly never even looked at in my life with any car, so I'm not sure how to source one. any relevant specs would be great. xx
Old Jun 14, 2017 | 05:47 AM
BeckBeck's Avatar
Alrighty so the weather has been awful and I haven't had a chance to get into any of this. I do however keep seeing my symptoms come up when pcv valve malfunction or hose leak is mentioned. I'm interested in adding that to my to-check list, but I'm not sure what kind of PCV valve we have in a 4.0L xj40 sov. Anyone got a pic and explanation for me? Tomorrow if the storm dies down a little I'll be getting into the throttle body and ICV after work.
Old Jun 14, 2017 | 05:56 AM
o1xjr's Avatar
A quick call to Jagdaim would be my first stop. Doug Findlay knows his stuff, if they don't have one he will know where to point you.
He will also know if there a generic one you can get.
Jaguar Spare Parts Supplier - Jagdaim - Australia's Largest Independant
http://www.jagbits.com/jaguarpcvvalve.php
Old Jun 14, 2017 | 06:07 AM
BeckBeck's Avatar
Jaguar PCV Valve New and Used OEM and Aftermarket Jaguar Parts Online Catalog
Thanks love, will do! Though I'm reading now that it doesn't even have a conventional pcv valve as such, and it instead uses a full load and part load breather hose system.. i think I should go ahead and do a mechanics apprenticeship to make owning this xj easier ;D
Old Jun 14, 2017 | 09:23 AM
Don B's Avatar
Hi BeckBeck,
There is no PCV valve on an XJ40. Crankcase breathing is managed by a series of pipes, hoses and restrictors which are designed to maintain a slightly negative air pressure in the crankcase under varying running conditions. I believe the info is in the Engine Management System manual:
AJ6 4.0L Engine Management System/OBDI Diagnostic Guide
Cheers,
Don
Old Jun 14, 2017 | 10:58 PM
BeckBeck's Avatar
Originally Posted by Don B
Hi BeckBeck,
Cheers,
Don
THANK YOU! This is such a helpful document!
Old Jun 16, 2017 | 02:15 PM
Don B's Avatar
Hi BeckBeck,
I moved the relevant posts from the Stalling thread to this thread so all the info regarding the mythical XJ40 PCV valve is in the same thread.
Cheers,
Don
