Hi,
I need to replace the pinion oil seal in my xj40 diff due to an oil leak. From what I've read in the Haynes manual and various posts on this forum, I need to mark the pinion nut, flange and shaft, and then realign everything on assembly. On inspection of my diff, the pinion nut appears to be damaged at the side - see attached pic. Will I required a new nut?
Pete
