XJ40 ( XJ81 ) 1986 - 1994
Rear rubber shock bushing squeak?
Old Oct 28, 2014 | 05:38 PM
DayOff's Avatar
Default Rear rubber shock bushing squeak?
On my '89, I recently replaced the front/rear shocks and used the aftermarket rubber shock bushings instead of the foam ones. Seemed to be a good suggestion at the time, but I'm getting a real bad squeak from my right rear when I go over bumps. Not a clunk, just sounds like something rubbing together behind the right side of the rear passenger seat...
I'd be curious if anyone had a similar issue...
Pete
Old Oct 28, 2014 | 10:11 PM
Don B's Avatar
Hi Pete,
Squeaks are very common on the rear shock bushings if they are not buttered with a lithium-based grease before assembly. Many of us have had to learn the hard way. See photo 6 in album 2 below:
Welcome to Jag-lovers - Members Photo Viewing Page
I tried the solid rubber bushes on the front but found they made the ride noticeably more harsh over bumps, so I switched back to the yellow foam bushes. They only last a few years, but they're the material the Jag engineers tuned the suspension for. The advantage of the solid rubber replacements is that they'll last many times longer.
Cheers,
Don
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
