XJ40 ( XJ81 ) 1986 - 1994
Recharging A/C 91' Sovereign
Old Apr 3, 2017 | 02:22 PM
Jagbro's Avatar
Default Recharging A/C 91' Sovereign
A/C on 91' my Sovereign blows cool, but not cold enough when temps are above 80 degrees.
Does the system in the 91's use the old R-12, or new R-34?...
I don't think I can do the r-12 recharge myself w/o environmental shop machines...
JagBro
Old Apr 3, 2017 | 04:27 PM
Lawrence's Avatar
Originally that car used R12 but it may have been converted? Usually there's a label on the fender with the A/C details/specs, but if not, you can tell by the type of charge ports as to whether or not it has been converted.
You'll have to google the port descriptions to see the differences.
Old Apr 3, 2017 | 04:33 PM
Jagbro's Avatar
Pretty sure its the old system. I just roll in to Firestone...
Old Apr 4, 2017 | 03:41 PM
frenchfairplaydriver's Avatar
Default Fresh air
Hello, for my part my jaguar of 1989, uses the gas R12, banned in europe. 2 years ago, I made a refill by myself with the gas duracool 12a, whose size of molecules are big compared to gas 134a. This prevents leakage. It always works as well.
Old Apr 4, 2017 | 05:41 PM
Lawrence's Avatar
Widely used in Canada, cools way better than R134A but of course duracool is just propane (not that there's anything wrong with that!)
Larry
Old Apr 5, 2017 | 09:37 AM
Jagbro's Avatar
I have the R-12. Do I charge using High Side or Low Side?
Old Apr 5, 2017 | 09:57 AM
Don B's Avatar
Charging is always done via the low pressure port. Lots of information online about servicing A/C systems.
For the record, since your system may have inhaled air and moisture via the same leak through which it has lost some of its refrigerant, it would be a good idea to have it professionally evacuated to get rid of the moisture and contaminated refrigerant before recharging it with the correct amount of new refrigerant (by weight). That's really the only way to restore the system to full efficiency. They'll also vacuum test the system to be sure the leak is not significant, and they may recommend that you replace the receiver/dryer. They'll also monitor their manifold gauges to ensure the system is operating properly and the refrigerant charge is correct.
Cheers,
Don
