XJ40 ( XJ81 ) 1986 - 1994
Relay?
Old Sep 12, 2010 | 10:06 PM
mrtalkradio's Avatar
Default Relay?
My fog lights and windshield washer do not work. I do hear clicking in the engine compartment though. I checked the Haynes repair book and I found the relay for the washer pump, cleaned it and reinstalled. I cannot find any relay for the fog-lights except for the fuses that are described and they are good, although I hear a relay or switch click when I try turning them on. Any direction here would be helpful. 1990 VDP
Old Sep 28, 2010 | 07:28 PM
Update on this issue. Silly as it sounds, the windshield washer works....when the car is running! Fogs are still out in the front, back fogs work. The headlight washer surely is not working.
Old Sep 28, 2010 | 07:47 PM
fritterfran's Avatar
MRTALKRADIO,
I believe there is a relay for the headlamp washer, either on the left or right front of the car. The relays are in clusters of 4 and behind the front headlamps. When you find it and clean up the connections, you might as well take care of the other relays while down there.
Hope this helps
Old Sep 28, 2010 | 07:55 PM
Will do thanks
Old Sep 29, 2010 | 08:02 PM
Lumppy47's Avatar
Check and clean grounds,and make sure they are tight
Old Oct 14, 2010 | 09:04 PM
FOG LIGHTS WORK! Finally. What was it? shhhhh the bulbs.
As far as that headlight washer, I checked the grounds, cleaned and sanded the relays. Still no go. But maybe it does it every 5 or 6 pumps from the washer? Do the wipers need to be on? Its probably user error are as most things with me.
Old Oct 23, 2010 | 10:24 PM
Robert's Avatar
When I bought my 1990 XJ6 (XJ40), I asked the previous owner about the front fog lights not working. He said that he hadn't been able to figure it out, but figured they had never been hooked up. Well, when I got the car home, I opened up the fog lights and - yep - no bulbs. Bought some new bulbs from NAPA and they work great!
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
asleach2889
Oct 1, 2015 01:53 AM
Mark SF
Sep 28, 2015 01:51 PM
