XJ40 ( XJ81 ) 1986 - 1994
Replacing Fuel Injector
Old Jul 18, 2009 | 01:53 PM
estunum's Avatar
Default Replacing Fuel Injector
Looking at the fuel injectors makes my head to think of removing one. Any instructions out there on replacing one?
One of them it's leaking, hopefully it's just an O ring. I know the steps to depressurize the fuel system, just not quite sure how to tackle the fuel rail injector.
Old Jul 22, 2009 | 12:44 AM
poboyblues's Avatar
There are I believe 4 small 8mm headed bolts on the injector rail that must be removed to seperate the rail from the intake manifold. Disconnect the fuel inlet and return lines. The entire rail comes out, but lift or pry carefully to break loose the orings. The injector is held in by a clip that looks like a square capital C. Just slide that out, and then carefully remove the injector from the rail. They aren't too hard to do. Reinstalling the rail can be tricky as the tips of the injectors must be lined up perfectly in their hole in the intake manifold. Lube all new orings with vaseline. Hope this helps a bit. It's been a long time since doing injectors on the AJ6 engine. We don't get many of these at the dealer anymore. Don't forget to replace all the orings on the injector tips, even if they aren't leaking.
Old Jul 27, 2009 | 09:15 AM
estunum's Avatar
Thank you poboyblues. The injector in question does not leak anymore. It was just that one time I noticed it. I decided to change it out, or at least check the O rings regardless. If it leaked once, then it must be damaged, no?
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
OkieTim
Sep 2, 2015 12:48 PM
