XJ40 ( XJ81 ) 1986 - 1994
Rust On The Outside Of The Gas Tank
Old Apr 28, 2016 | 01:17 AM
Wewillbfree's Avatar
Default Rust On The Outside Of The Gas Tank
Hello Friends
Just read Mad Russian's post on rust inside of the gas tank. Didn't want to take over his thread.
So I was going to clean up the ground connections in the trunk. Luckily I did because I found moisture in the trunk with mold started to grow. I'm sure I'm able to save the carpets.
Notice some rust on the top of the gas tank. Pulled off the padding above the tank. So after I get rid of the rust is it a good idea to ruff up the tank with sandpaper and spay primer on it.
Also after reading about rust inside the tank. Should I pull out the feul pump and inspect the inside. Especially since it's all ready to go.
Thanks for your time.
Old Apr 28, 2016 | 02:16 AM
Lawrence's Avatar
On the 88, isn't the fuel pump outside the tank?
see this thread ..
https://www.jaguarforums.com/forum/x...t-start-39963/
Larry
Old Apr 28, 2016 | 09:52 AM
Thanks Larry
Looks like a lot of fun. Specially since I'm not a double jointed miget.
Hopefully I could avoid removing the pump for a long while. Will take a look through, maybe I could clean it up on the outside.
Old May 23, 2016 | 02:54 PM
Mad_Russian's Avatar
Originally Posted by Wewillbfree
Hello Friends
Please keep in mind, removing fuel tank to get to the pump requires disconnecting 2 hoses under the tank above the rear differential. You will need to jack the car up and then remove the 2 clamps that are holding the fuel lines. Once you do that, the tank slides out. Its not terrible, but is painful
Old May 23, 2016 | 03:11 PM
Hello Mad Russian
When you do unclamp the hoses, how much fuel comes out?
Should the feul be all used up first?
I would like to think that I wouldn't run it low ( ever ), just to avoid potential problems.
Old May 23, 2016 | 03:18 PM
Hello Mad Russian
When I did mine, it leaked but not a lot. The design of the fuel pump will not let just "leak out". So only what was in the hose from the fuel pump to the bottom of the tank. Have a towel handy to catch the minor spillage. I would definitely do it on more or less empty tank. Because even 5 gallons is very heavy and difficult to maneuver while trying to take the tank out.
Very important. Do not let those clamps fall on top of the rear differential. It will be a nightmare of monumental proportions trying to find them again. Use needle nose pliers or similar tool to pull them up and over the hose. It's not hard, just he careful.
Old May 23, 2016 | 09:12 PM
Don B's Avatar
Wewillbefree,
On your '88 with the external fuel pump, all or most of the remaining fuel may be able to spill out when you disconnect the two hoses from the bottom of the tank, so you will want to siphon out as much as possible.
Mad_Russian's advice applies to the '90-'94 cars with the fuel pump inside the tank. On those cars, the fuel pump canister or module connects to both the outlet and return ports on the bottom of the tank, so only some of the fuel in the canister spills when you disconnect the hoses.
Cheers,
Don
DJS
May 23, 2017 04:37 PM
fward
Jul 24, 2016 01:10 PM
Navyflyer
XJ40 ( XJ81 )
Apr 15, 2016 09:57 AM
wforslund3
Mar 31, 2016 12:14 AM
RonaldP
Mar 30, 2016 02:34 PM
