XJ40 ( XJ81 ) 1986 - 1994
Steering Gear
Old Mar 3, 2009 | 11:21 PM
estunum's Avatar
Default Steering Gear
I have a bit of a squeaky problem. The noise comes from the front driver side. When ever someone gets on or off, I go over bumps, or simply driving from stopping and going, will make the noise. At first I thought it would be the road spring, or even the damper. When I got under the car, and had someone move the car around, the noise seems to come from the steering gear. It's a rod that attaches to the wheel, to a spring (which is where the squeak seems to come from) to the vehicle. If this is the case, is this a simple replacement? How about just greasing the spring? Or is the squeak a sign of needed replacement?
Old Mar 4, 2009 | 04:58 AM
grommet's Avatar
I'm not sure what you mean by " connected to a spring, to the vehicle". perhaps you could post a picture of the suspect
hoodun
Nov 20, 2022 02:35 PM
derek15301xjr
Oct 20, 2015 07:39 PM
Poet
Oct 2, 2015 09:00 AM
jtflanaga
Sep 29, 2015 12:59 PM
jtflanaga
Sep 28, 2015 01:55 PM
