XJ40 ( XJ81 ) 1986 - 1994
Tank goes whoosh when cap is removed, positive or negative pressure?
Old Oct 23, 2023 | 11:29 PM
JensenHealey's Avatar
Default Tank goes whoosh when cap is removed, positive or negative pressure?
I am concerned that maybe my old MY94 XJ6 is not properly venting the tank. After reading through various posts on this subject I have understood that a small amount of positive pressure is normal (2psi) but I am concerned that I might have a problem with negative pressure in the tank.
I would like to put some sort of pressure gauge into the system to check to see if it is indeed a slight positive pressure (probably OK) versus a possible large amount of negative pressure (bad result).
Can anyone suggest where I might be able to hook up a pressure gauge in the system? Or perhaps another way to make sure which type of pressure I am getting in the tank?
Old Oct 24, 2023 | 03:34 AM
Sovejag13190's Avatar
Hi, to the left side of tank there is valve one direction this is this valve who have problem
Old Oct 25, 2023 | 03:12 AM
Is it possible in pulling the gas tank out to replace the fuel pump that I might have somehow damaged this valve?
When I have to pull the tank to replace the pump I don't fully remove the tank. I just pull it out on the opposite end from the filler neck far enough to reach the top access port.
Then I let it hang there while I remove the access port to reach in to get to the pump.
Old Oct 26, 2023 | 01:32 AM
Control all hoses that not bendiing.
Morey
Aug 28, 2020 05:16 PM
cheseroo
Nov 17, 2018 05:45 AM
tutilee
22
May 27, 2017 06:47 AM
razorboy
Oct 26, 2015 10:29 AM
GordoCatCar
Jul 28, 2015 06:07 AM
