XJ40 ( XJ81 ) 1986 - 1994
timing cover leak
Old Apr 15, 2022 | 08:33 AM
Jim.Carlton's Avatar
Smile timing cover leak
I am contemplating the purchase of an
xj40 that seems to be leaking from the timing cover. Is this an expensive fix? If it is a gasket, can anyone recommend a source?
Old Apr 15, 2022 | 07:57 PM
Bez74's Avatar
Hello Jim
Steps to replace valve cover below from the Haynes book of knowledge
Availability of parts - no longer available from Jaguar - but found this on e-bay
https://www.ebay.com.au/itm/12213421...4aAvXlEALw_wcB
Steve
Old Apr 16, 2022 | 06:40 PM
jerry_hoback's Avatar
I think it needs to be ID'ed with more certainty. Steve makes an excellent suggestion of changing the cam cover gasket. It is a known problem area and the spark plug tubes are also hard to seal. It is possible that the oil could be dripping from the front lower corner there, or less likely the distributor seal. If its the front crank seal as you suggest, I don't think it would be a Hard job but it would certainly be "in depth." However I have not done that job YET myself. Whatever the case its not fatal or too too bad a job. Good luck!
Old Apr 16, 2022 | 10:32 PM
Bez74's Avatar
Sorry - read the post incorrectly - for some reason I thought it said valve cover
Old Apr 17, 2022 | 02:11 AM
Lawrence's Avatar
Timing cover gasket part number is NBB2119AA try googling the part number - I know Jaguar classic parts has them in stock for about 10 bucks but you'd have to get it from the UK. If It were my car and I couldn't get one I'd just trace the timing cover and make one. I've also made gaskets by scanning the design into a pdf and cutting them out with a cricut plotter.
Larry
tomcoo
Jul 23, 2019 05:19 PM
Daim
Jul 30, 2017 10:36 AM
Jagbro
XJ40 ( XJ81 )
Mar 6, 2017 02:49 PM
osyris
Nov 27, 2013 09:43 AM
Fedoraja1
Aug 9, 2011 09:39 PM
