XJ40 ( XJ81 ) 1986 - 1994
transmission issue.
Old Jan 20, 2012 | 07:41 AM
bert_vdp's Avatar
Default transmission issue.
i was given a 91 Vanden Plas by my father that he had owned for a few years. He told me that it had a few issues. I came to find out that when i turn the key in park it doesn't turn on but it will start in neutral, so i think thats a neutral safety switch issue but when i put the car in park it doesn't stop, it travels a few feet, then stops. could it be related to the first issue, or am i gonna have to shell out some money to get this fixed.
Old Jan 21, 2012 | 11:54 PM
limegreenclown's Avatar
my 91 does exactly the same thing, i just start it in neutral and use the handbrake when i stop.
ive always suspected a loose linkage on mine and havent has a chance to piddle with it, let me know if you get this fixed
Old Jan 23, 2012 | 05:33 PM
mrtalkradio's Avatar
If you can get under there (safely and securely) on the housing of the tranny you can see the linkage cable, it is very easy to adjust if that is the problem. You don't need to get into that switch to do what I am explaining to you. It actually sits right before the switch on the outside of the housing. Try that first and see if you can adjust it. If your car is in park, and you see that linkage cable is loose, you have found your issue.
Old Jan 24, 2012 | 09:20 AM
bert_vdp's Avatar
thanks so much. i was fearing the worst.
Old Jan 25, 2012 | 10:26 PM
rolexmike's Avatar
I hope everything works out fine, i wonder if this is a common issue on a 91? I have heard of this problem before also.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
bdboyle
Sep 16, 2019 05:58 PM
SouthernGypsy
Sep 23, 2015 04:06 AM
lovemyjag78
Sep 14, 2015 07:42 PM
