XJ40 ( XJ81 ) 1986 - 1994
Transmission problem
Old Mar 15, 2018 | 01:11 PM
Thumprr1226's Avatar
Default Transmission problem
I have a 91 sovereign transmission problem it runs and drives it drives in drive it will not downshift it will not upshift, can somebody please help me figure out this problem, also it does clunk hard when putting into reverse
Old Mar 15, 2018 | 01:14 PM
NBCat's Avatar
What is the number of kilometres/miles on the vehicle?
Has any work recently been done to the engine or gearbox?
What is the level and condition of the gearbox fluid?
Old Mar 15, 2018 | 01:16 PM
130000 miles,fluid full and red
Old Mar 15, 2018 | 01:18 PM
Just replaced fuel pump
Old Mar 15, 2018 | 01:33 PM
NBCat's Avatar
Have you changed the fluid and filter?
If the fluid and filter are new, from what you describe as symptoms, there may be a problem with the valve body.
Old Mar 15, 2018 | 01:34 PM
Originally Posted by Thumprr1226
I have a 91 sovereign transmission problem .....
Welcome to the forum Thumprr1226,
I've moved your question from General Tech Help to XJ40 forum. This is the place to post technical questions about your model.
I will change filter and fluid to start.
Old Mar 15, 2018 | 04:03 PM
Also sport mode does not work
Old Mar 15, 2018 | 05:59 PM
Don B's Avatar
Hi Thumprr1226,
Welcome to the Jaguar Forums!
Is the transmission fault warning lamp illuminated in the instrument cluster? If so, your transmission is in Limp Home Mode (LHM), which locks it in 3rd gear. On our '93, the most common cause of LHM was oil contamination of the electrical connector for the Throttle Position Sensor (TPS). This connector clips to a bracket on the intake manifold elbow just to the left of the throttle body. Separate the two halves and flush them with zero-residue contact cleaner (CRC is a well-known brand). Allow to dry and reconnect.
Regarding the clunk when you put it in Reverse, what is your engine rpm at idle?
Cheers,
Don
Old Mar 16, 2018 | 12:04 AM
engine rpm about 850
Old Mar 16, 2018 | 12:15 AM
do you have a picture?
Old Mar 16, 2018 | 12:56 AM
do i have to disconnect the battery?
Old Mar 16, 2018 | 08:07 AM
Don B's Avatar
Your idle is too high - it should be closer to 650-700 rpm. You may have a vacuum leak or a problem with the Idle Air Control Valve (IACV). See the photo albums at the link in my signature for information about cleaning the IACV.
Don
Old Mar 16, 2018 | 08:14 AM
Don B's Avatar
I don't have a picture of the transmission warning lamp, but your Driver's Handbook/Owner's Manual probably contains an illustration. Basically, the light looks like the outline of a transmission housing, possibly with an X through it, and if I recall correctly, it is on the left edge of the instrument cluster.
Old Mar 16, 2018 | 08:15 AM
Don B's Avatar
You do not have to disconnect the battery to clean the TPS connector - just leave the key out of the ignition.
Old Mar 16, 2018 | 10:23 AM
That didn't fix it.
Old Mar 16, 2018 | 11:23 AM
The connector was dry,not the problen.
Old Mar 16, 2018 | 07:00 PM
Don B's Avatar
Are you certain you checked the correct connector?
Is the transmission warning lamp illuminated?
Old Mar 16, 2018 | 07:10 PM
Yes it was dry.has like 7 wires attached to the tps
Old Mar 16, 2018 | 07:11 PM
Check engine light is on.
