XJ40 ( XJ81 ) 1986 - 1994
Trunk Struts
Old Apr 13, 2016 | 12:42 PM
Navyflyer's Avatar
Default Trunk Struts
Trunk will not stay in the up position. Purchased two new trunk struts but can't seem to loosen the square nuts on the old struts by turning counter clock wise.
Is there something I am missing?
Old Apr 14, 2016 | 06:37 PM
jerry_hoback's Avatar
My struts, which have admittedly been replaced, just have the spring clips over the ball sockets. Just get behind the clip with a small screwdriver and pry it outward. The strut will come right off. Good luck.
Old Apr 15, 2016 | 09:57 AM
Don B's Avatar
Navflyer,
Jerry is right - you just need a small flat-bladed screwdriver to replace the struts. To remove the old ones, slip the blade under the metal spring on the back of the strut end and pry it out just until it snaps into its release position. You can then pull the strut end off of the ball stud mounted to the body or trunk lid. Repeat for the other end of the strut. To install the new struts, you can usually leave the springs in their down or latched position and simply press the ends onto the ball studs until they snap into place. Here's one of many videos available online:
Cheers,
Don
Griff79
Apr 15, 2016 08:04 AM
ken6889
Apr 13, 2016 01:14 PM
Steve W
Apr 12, 2016 05:28 PM
tdyer
Apr 8, 2016 07:09 AM
