XJ40 ( XJ81 ) 1986 - 1994
VCM Code
Old Apr 7, 2022 | 12:12 PM
Jagbro's Avatar
Default VCM Code
91' XJ40 is stalling and going into limp mode every time I start it. Getting this message on my VCM: HLCb5.0 (or something like this). Anyone know what this could be?
Old Apr 7, 2022 | 12:15 PM
Jagbro's Avatar
Disconnecting the battery for a few seconds and reconnecting it helped for a while, but no more..
Old Apr 7, 2022 | 02:41 PM
Jagbro's Avatar
Also all instrument cluster gauges are not functioning now
Old Apr 7, 2022 | 05:35 PM
jerry_hoback's Avatar
I'm not familiar with that as a "code" for the OBD1 system. It should be something like ff46. Has your car been extremely wet or gotten zapped somehow? I wish I knew.
Old Apr 7, 2022 | 05:39 PM
You might try disconnecting both cables and touching them together for 30 seconds or more. This should clear memories in the computer of any "bad dreams" it had. I had to use a jumper cable to do mine. Just FYI.
Old Apr 7, 2022 | 05:40 PM
Jagbro's Avatar
Ok Jerry, I will try that
Old Apr 14, 2022 | 09:57 PM
Don B's Avatar
Hi Jagbro,
Jerry's suggestion of a hard reset may help. Be sure to disconnect the battery negative cable from the battery before you use a jumper cable to connect it to the positive battery cable for at least 2 minutes. Then reconnect the battery and see where you stand.
Check the fuses related to the instrument cluster - one may have been blown.
The message from your VCM is implausible, perhaps due to low battery voltage, a voltage issue to the instrument cluster, or corruption of one or more electronic control units.
Cheers,
Don
galearmstrong
Mar 26, 2024 10:34 AM
Abaco Potcake
XJ40 ( XJ81 )
Oct 14, 2017 04:24 AM
johnkent
Sep 26, 2017 12:19 AM
mick99
Jul 13, 2015 05:46 AM
