XJ40 ( XJ81 ) 1986 - 1994
XJ40 engine swap
Old Mar 9, 2007 | 05:50 PM
bigdreams05's Avatar
Default RE: XJ40 engine swap
Do you know how to weld? You'll have to make custom motor mounts and brackets, you'll need to redo the wiring harness which can turn out to be a real pain in the ****, you'll need to make sure the radiator mounts up nicely, you'll need to make sure that the new tranny goes up smoothly as you'll probably need to make some cosmetic changes inside if the shifter is different on the trannys, you'll need to make sure that the drive-shaft fits with the differential in the new car, you'll have to rewire the tranny as well! I may be going overboard with the mounts and brackets, or the drive shaft and interior, as I just saw that it's from one XJ6 to another. However, redoing the wire harness is a definite.
Old May 16, 2007 | 04:44 PM
ken@britishparts.com's Avatar
The 3.6 and 4.0 engines don't swap. You will have all kinds of issues.
Old Jun 8, 2007 | 11:49 AM
XJ40ish's Avatar
Ahem... Get your 4.0 rebuilt, or as an option get a used 4.0 from the same model and year. Overall it will be much easier and far less nasty suprises than in changing over to something the car was not designed for. I've found no matter how easy people say it is to swap, it never is. Stick with the 4.0 youwill find it's the best and cheapestalternative.
Old Jun 10, 2007 | 06:03 PM
Jose's Avatar
Motorcars Ltd. sells used engines for $399.00. Call them and seewhat they have.
FrickenJag
Jun 16, 2025 02:15 PM
rusty37
Apr 5, 2020 07:40 PM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
