XJ40 ( XJ81 ) 1986 - 1994
XJ40 no start. Crank ok. Spark ok. Fuel ok.
Old Mar 6, 2014 | 09:13 AM
jaguarlars's Avatar
Default XJ40 no start. Crank ok. Spark ok. Fuel ok.
So this is a 1989 a bought that has been standing still for 14 years. It runs when injecting start gas but not by itself. Injectors will not engage fuel in cylinders. There is no corrosion as the car has been in warm storage and it has only done 80000km. It looks very good condition and started last year.
Fuel pump ok and I have preassure at fuelrail. Checked wiring at ECU and it looks like new. Ideas anyone?
Old Mar 6, 2014 | 07:08 PM
Rob Evenson's Avatar
Jaguarlars,
Not a lot of information in your post to assist with. I would start with the injectors since you suspect a problem with them. However, if all are not operating the problem will be in front of them.
Go to this link and download the XJ40 Haynes manual:
https://www.jaguarforums.com/forum/g...r-index-50609/
Scroll down and click on the XJ40 link and open the manual or download and go to the section 4 and read over the entire section, especially the section for diagnosing the injectors. Also, go to the back of the manual and look over the schematic in section 12, page 17. It will give you a good idea on how the system operates.
Considering how long the car sat, there's a number of thing that could be in disrepair. Be sure to inspect all hoses, seals and the air intake system for leaks or cracks.
One more thing (Beat you to it Don! ), clean every earth ground you can find. There are about 5 of them in the engine bay that I can think of. Battery negative post, firewall (above wiper assembly), one on each wing (near the headlights, and the engine earth ground (have to get under the car). Clean any and all grounds that you find, these cars don't like dirty grounds. Even if the car was garaged all that time, there is still oxidation that occurs. Don't forget, the ECU has a ground as well.
Start with the above and report back so we can help some more.
Old Mar 6, 2014 | 10:38 PM
Don B's Avatar
Originally Posted by jaguarlars
So this is a 1989 a bought that has been standing still for 14 years. It runs when injecting start gas but not by itself. Injectors will not engage fuel in cylinders. There is no corrosion as the car has been in warm storage and it has only done 80000km. It looks very good condition and started last year. Fuel pump ok and I have preassure at fuelrail. Checked wiring at ECU and it looks like new. Ideas anyone?
Just so I can picture in my mind your test that has resulted in the engine running, how are you injecting the start gas?
Thanks,
Don
Old Mar 7, 2014 | 04:44 AM
jaguarlars's Avatar
Default Solved
5 out of 6 of injectors where stuck. Probarbly because of 15 year old bad swedish fuel... No it runs perfect!
Old Mar 7, 2014 | 11:50 AM
Don B's Avatar
jaguarlars,
Glad to hear you figured it out! Below are links to photos I took of the process I used to clean the fuel injectors on our '93, and how I replaced the filters and O-rings using an inexpensive kit sold on eBay.
Cheers,
Don
Welcome to Jag-lovers - Members Photo Viewing Page
Dagny
Jun 11, 2024 01:06 PM
Charlene n John
Sep 28, 2015 06:01 AM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
joesoap
Sep 10, 2015 01:09 AM
Charlene n John
Sep 6, 2015 11:03 AM
