XJ40 ( XJ81 ) 1986 - 1994
XJ40 sovereign won't start after 2 years
Old Jan 3, 2022 | 02:59 PM
XJSov's Avatar
Default XJ40 sovereign won't start after 2 years
Hello, i try to start my jaguar xj40 sovereign,model 1988, 3,6 after 2 years sitting on . I poor new fuel 95,
The gear shift on parking, I remove the spark plug and clean them,
the engine crank,but won't start.I use the spray on the air filter,then the engine start for 3 seconds,then stop again.The oil pressure is around 4. I see the fuel light flashing after 8 liter of fuel in the tank.May be the problem is not enough fuel? Or fuel pump ,I don't know,any suggestions?
Old Jan 4, 2022 | 11:21 AM
Lawrence's Avatar
When you switch on the ignition you should hear the fuel pump running for a few seconds. If no sound, that could indicate there is a problem with the fuel relay or the fuel pump.
You can also open the fuel line in the engine compartment to see if fuel is present in the fuel lines.
Larry
Old Jan 4, 2022 | 11:16 PM
Parker 7's Avatar
Never put the battery back in backwards if you pull out to recharge it
The fuel pump will run for 4 seconds then off by design
It will turn on again when the crankshaft position sensor sees engine rotation fot the duration of your drive
You can jumper the fuel pump relay across socket 30 and 87 to directly run the fuel pump
You should hear the pump running at this point
use a blade type connector for better current flow through the heavy gauge wire jumper and not just jamming some wire into the sockets
The auto parts store can help build this jumper with a tool and parts kit they keep behind the counter
The pump will run at all times with the key in your pockets so plan accordingly
Old Jan 5, 2022 | 12:07 AM
Parker 7's Avatar
Sometimes after sitting the fuel pump can get stuck and by starting the car with a battery charger connected with a higher voltage then just the battery can free up a stuck pump motor
A 50 amp charger would be best as a 10 amp charges at a lower voltage but is still above a fully charged battery of 12.75 volts DC
an example would be say 15 volts for a 50 amp charger vs. 13.5 volts for a 10 amp charger , that's how they work to deliver amps rating
This additional voltage may force the pump free as voltage is a force you want to increase
You can bang on the fuel tank with your fist to jar the fuel pump loose and to run , once running it will work itself free and probably continue with no further problems limited by the service life of the pump motor
Old Jan 5, 2022 | 11:47 AM
Lawrence's Avatar
In the case of later cars this could work, however the OP's car is an 88 with an external fuel pump.
Larry
Old Jan 7, 2022 | 03:05 AM
Brett J's Avatar
my money is on the fuel pump
mgb77
XJ40 ( XJ81 )
Dec 8, 2013 10:47 AM
AlphaDogX24
Nov 16, 2012 01:49 PM
malibudav
XJ40 ( XJ81 )
Apr 22, 2012 10:39 PM
thedreamender
XJ40 ( XJ81 )
Jul 16, 2011 03:41 PM
george
XJ40 ( XJ81 )
Nov 18, 2008 03:34 PM
