XJ40 ( XJ81 ) 1986 - 1994
xj6 gold
Old Dec 28, 2011 | 10:52 AM
elliot evans's Avatar
Default xj6 gold
hi all,
got this intermittent pain where the fuel pump doesn't make a noise on turning the ignition on, i'm certaian it's the relay but other than located somewhere in the car does anyone know where it is ?
many thanks Elliot
Old Dec 28, 2011 | 03:18 PM
MidwestJag's Avatar
Good day, Elliot:
I think it depends on the model year. Do you have the owner's manuel? otherwise, go under the hood and to see if the relay covers are still in place. The covers (at least on my '91) were labeled and could provide the answer you seek.
Scott
Old Dec 28, 2011 | 04:28 PM
Jagfix38's Avatar
It depends which model you have (You didn't mention which year?):
1988-89 - Brown relay located under the dash behind the kneeboard
1990-92 - Yellow relay located near the brake pedal housing in the engine bay
1993-94 - Light Blue/Black relay located in the right rear corner in the trunk
Old Dec 28, 2011 | 05:34 PM
mrtalkradio's Avatar
Changing relays never hurts anything. If you search the forum, you will find your issue, and fix it. You can try this, per my experience. Get someone else to get under the car and put their hand around that fuel pump while you turn the key. It could be seized. You won't know that doing it your self. I too couldn't hear the whine, but I had power going to the pump. I then proceeded to tear the car apart under the passenger kick plate. I even replaced the ECU! it wasn't till a friend came over and did what I explained. 15 minutes later she started right up.
Old Jan 7, 2012 | 08:44 AM
cuengineer's Avatar
Also, if you are still locating the relay, if your car is like my 93, there are several of the same relay in the car so you can pull another one to see if that allows the fuel pump to work. I have also pulled a relay and changed with another and then they both worked -- apparently because of a connection issue at the blades.
mat32essex
Oct 3, 2015 04:12 PM
baskervillema
Oct 1, 2015 06:43 PM
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
42Ajd
Sep 26, 2015 07:04 PM
