1973 XJ6 S1 Cut Out, Rough Idle & Misfire
Old Jun 1, 2025 | 10:52 PM
minder's Avatar
Default 1973 XJ6 S1 Cut Out, Rough Idle & Misfire
Hi,
I just got my S1 XJ6 back from the shop from a full rear deferential rebuild.
  • Unfortunately the car is no longer idling.
    • It's super lumpy
    • Misfiring
    • Hesitating on acceleration,
    • Zero acceleration on incline.
    • The choke doesn't seem to be working now either.
From reading the forum I spent today changing:
  • Ignition coil
  • Sparks plugs
  • Fuel Filter
  • Fuel pressure regulator
  • Checked hoses for vacuum leaks
Any direction super appreciated. I'm trying find a knowledgeable Jag store in Portland to tow to, no luck yet.
Minder
Old Jun 1, 2025 | 11:52 PM
You have covered the basics, BUT, HT leads, all 7 would be my next "to do".
Relationship to the rear end, NONE, but someone has fiddled, and finding that is the time thing.
Old Jun 2, 2025 | 12:43 AM
minder's Avatar
Thanks @Grant Francis I'll check out the plug wires.
Totally agree, it's going to be a test in patience & perseverance :-)
Old Jun 2, 2025 | 01:01 AM
Fill the beer fridge, works very time.
Old Jun 2, 2025 | 05:01 AM
Forgot, it happens.
I will assume you still have Contact Points Ignition??
If so, replace the Condensor inside the distributor. They be little, but can reek havoc.
Old Jun 2, 2025 | 05:56 AM
redtriangle's Avatar
Did the car spend time outside the shop in the rain?
Check for water in the fuel. Those filler caps can often leak in heavy rain esp. if the drain tubes are blocked.
Just a thought, as I have experienced the same symptoms.
Old Jun 2, 2025 | 07:53 AM
minder's Avatar
Thanks, I'll check the distributor.
Old Jun 2, 2025 | 07:55 AM
minder's Avatar
Thanks @redtriangle I had not thought of that, Ill look into it.
I'm always having to clean out those drainage holes :-)
Old Jun 2, 2025 | 01:15 PM
minder's Avatar
Not sue if it is relevant, but I'm getting smoke puffing out of the circled pipe when firing up the car.
I replaced a kinked hose off of the fuel rail to the air box, but it did not help :-(
Old Jun 3, 2025 | 03:00 AM
Well, it seems to me your anti-smog/pollution control set up is causing problems.
You don't need all that crap strangulating your engine.
I would remove it all, and chuck it. Severely.
Old Jun 3, 2025 | 11:33 AM
minder's Avatar
Thanks. Good shout. I think I found a mechanic familiar with the Jag.
Getting it towed there on Thursday.
Old Jun 7, 2025 | 06:28 AM
o1xjr's Avatar
My S1 did this a few years ago. Ended up putting in electronic ignition. Never a problem after that.
Old Jun 7, 2025 | 08:14 AM
Doug's Avatar
The circle cover two pipes: the air injection pipe and an air conditioning pipe. Neither should have smoke!
If it's the air injection pipe emitting smoke then the fix will be simple: replace the check valve. It's the (sort of) bell-shaped device next to the cam cover; to the right in your photo. These are readily available.
Almost certainly not related to your running problem, though.
The air injection system is fairly benign. It simply injects fresh air into the exhaust ports. That's it. This in itself is not detrimental to engine performance... although the belt-driven air injection pump does draw a couple horsepower.
A failed checked valve, however, should be replaced as the exhaust gas travelling the wrong way (into the air injection pump) isn't a good thing.
Old Jun 10, 2025 | 12:47 PM
minder's Avatar
Great call out. I was chuckling to myself, as I purchased an electric ignition & had the jaaaggg towed to the specialist today.
Super great guys, that informed me I already have the electric set-up :-)
Ill update the thread once the chaps conclude their diagnostics.
Old Jun 10, 2025 | 12:50 PM
minder's Avatar
Fantastic Doug, thank you very much for the info. I'm passing it on to the shop I took it to.
I'm in the Portland area, I'm hoping this 2nd shop is significantly more knowledgeable than the 1st :-)
Old Jun 11, 2025 | 10:37 PM
minder's Avatar
Thanks Guys. I finally found a credible local shop. Unfortunately looks like I need an engine rebuild :-( Super surprised as the previous shop said the engine compression test was excellent, then took me for over $4k to rebuild my rear differential (which i only did on the basis of a strong engine.). Insult to injury, the new shop were very surprised why the back end would need rebuilding, given the awesome condition of the Jag. Now I need to figure out to sell it as a mechanic project or LS swap it..... Rough classic owner day for sure :-)
Old Jun 12, 2025 | 06:15 AM
What rotten luck, however there must be heaps of good used XK engines out there that you could swap over.
Old Jun 21, 2025 | 06:00 PM
minder's Avatar
I'm seeking a replacement engine. I'm surprised the engine gave out so quickly.
Old Jun 22, 2025 | 08:48 PM
Any idea of the engine's milage?
They usually only fail if neglected (or abused).
Old Jun 23, 2025 | 09:30 AM
minder's Avatar
@redtriangle that is why I'm so perplexed by this. I've owned the car for a few years & spent continually to keep it reliable as a daily driver. Having recently put over >$6k in work, as I was reassured by the shop that the engine was in tip top shape. It has around 140,000 miles. I'm finding it challenging to find knowledgeable folks in the region, & not being very mechanically minded, I'm rather unsure what is what now. Whilst I'm hesitant to do so, I might have to bite the bullet & sell it as a project car.
