1984 xj6
Old Apr 2, 2013 | 11:12 AM
  #81
trymes's Avatar
On the S1 you are talking about? I don't think that the modification is that difficult, just connect the lines from the tanks to a "T" connector, then out to one pump. I would put it back to stock, though. Some think that the second pump is one more thing to break, but I prefer to think of it as a built-in spare in case the other one dies.
All depends on how you look at it!
Old Apr 2, 2013 | 07:32 PM
  #82
Ahabiam's Avatar
My series 3 came with a similar cluster in the boot. Tanks come together into one T-fittting and then to the pump. i also do not see a transfer valve. On yours, it looks like the fuel cell just takes the place of the tanks in the wings. I wonder if that is because the wing tanks need work, or if they didnt want to mess with a problem in the system. Putting it back to stock may be more work than you think.
Old Apr 13, 2013 | 03:41 PM
  #83
Paratrooper54's Avatar
Ok, first successful repair has been made to my 1985 XJ6! (I'm new to auto repair and the only thing I've done prior to this was change my oil). I've installed the High Torque starter from The Driven Man and there is a 100% improvement to starting the car. Before I would sometimes have to crank the engine a couple of times before a successful start and then even when started I would have to keep my foot on the throttle for a minute or two to keep it running. Now BAM! starts on first turn and idles perfectly.
Now my next project, I need to replace all bushings as the ones that are on the car seem to be the original ones and are disintegrating.
Question: Where can I buy a polyurethane bushings?
Old Apr 13, 2013 | 04:37 PM
  #84
Fraser Mitchell's Avatar
This guy seems to have them ALL !
Poly bushes for Jaguar and Daimler - SC Parts - Poly bushes for Jaguar and Daimler
And a US supplier here: -
http://www.v12s.com/polyxjscc.html
You can lose a lot of the refinement by fitting these.
Old Apr 13, 2013 | 04:55 PM
  #85
Ouch, to replace all bushings will cost me a little over $700. I'm still debating whether or not to keep the 1972 or the 1985 hmmmm we'll see when the 72 arrives next week.
Old Apr 13, 2013 | 04:58 PM
  #86
You don't have to replace them all at once, and some of the silentbloc ones are probably OK for the time being, (rack bushes excepted !)
Old Apr 13, 2013 | 06:05 PM
  #87
ah I just bought bushing and tie rod upgrades for the entire car. the bushings, so I was told, will fit either my 1985 or the 1972. Looks like I'll have a smooth riding car in the near future.
Old Apr 14, 2013 | 06:05 PM
  #88
Chris Willis's Avatar
I wonder what the $7000 covered .. Solid body and interior your way ahead . I'd start looking for parts at "everydayxj". Also eBay. Parts mostly available. This is a great site for info . These guys have walked me thru several fixes on my 86 xj6. I've found it to b a very pleasurable driver and surprising head turner. Enjoy
Old Apr 17, 2013 | 06:56 PM
  #89
So I received my 1972 XJ6 and find that it needs AAAAAA LOOOTTTT of work. Going to wait for it to stop snowing to determine how much work is required. But I do love the body style and will work on it myself. One of the first major upgrade is to work on the Carbs as I think that's the most important being that I'm in Colorado and I think the altitude will affect drivability over everything else.
Question is: Which carb upgrade will work best and is most versatile when dealing with changing altitudes?
Old Apr 18, 2013 | 12:17 PM
  #90
trymes's Avatar
Interesting. Post up some photos and more details on the '72 in a separate thread!
As for the carbs, you can see my thread on the same topic. When it comes to carburetors, it is often best to start with the type you already know and love (if you, in fact, already know and love a particular type of carb). THose raised on American cars and carbs often prefer Weber downdrafts, while those who learned on British cars often prefer SUs.
In the end, the best idea is to make sure that whatever carbs you have are in good condition and working properly. There is nothing wrong with the Strombergs, in and of themselves, but the manifold and dual throttle arrangement is a bit wonky. I personally prefer SUs to the Strombergs, but I know better than to claim it's a purely objective preference. My reasons are:
  1. Strombergs are FAR more complicated than SUs (or at least it seems this way due to #2).
  2. I am FAR more familiar with SUs, where I barely know anything about Strombergs.
  3. I come from the MGB community, where Strombergs are generally disliked because the later, emissions-strangled cars were fitted with single Strombergs (instead of dual SUs).
Considering how expensive it would be to source the manifold(s) and carburetors to change from the Strombergs to anything else, I would first plan on having the Strombergs rebuilt by a WELL-KNOWN expert (Joe Curto in NY comes to mind). Then reinstall them and see how they perform.
The BEST thing you can do is to send the distributor off to Jeff at Advanced Distributors and have him rebuild the distributor and convert it to Vacuum advance from vacuum retard.
Tom
Old Apr 18, 2013 | 12:58 PM
  #91
Thanks for the well written advice, don't understand any of it (this is my first carburated car) but I have a friend that's been helping me that's very fluent with carbed cars and I'll let him translate it for me! Ha! I'm learning as I'm repairing.
Old Apr 18, 2013 | 03:18 PM
  #92
trymes's Avatar
Glad to help if I can. Do be aware that, if your friend is used to American style carburetors, such as a QuadraJet on a Chevy 350, he is unlikely to know all that much more about a pair of Strombergs than you are. Generally, those that know and love common American setups just start pulling their hair out the first time they see the funny-looking dual British setup and blame every single problem the car has on them.
The proper process for tuning the car is:
  1. Verify the Ignition system is working properly (cap, rotor, wires, plugs, timing).
  2. Verify that the Intake and Emissions Equipment are also properly working (no vacuum leaks, etc).
  3. Tune the carburetors.
John Twist from University Motors in Michigan has a number of good videos on tuning SUs and Strombergs, including how they work, etc. Check out his channel on YouTube. I specifically recommend the videos about the Strombergs, "Secrets of the SU Carburettor" parts 1 and 2, and the video on tuning SU HIF carbs, which will at least give you the basic idea of the process for tuning the Strombergs, even if the details are different. I also have included a video of someone else showing how to balance a pair of Strombergs using a hose in the ear.
Good luck!
Tom
Old Apr 18, 2013 | 06:08 PM
  #93
Thinking about rebuilding the Carbs myself unless Paltech can upgrade to automatic choke with the $500 price tag. but sending the distributer off to get rebuilt next week. I'll let you know how things go in about 5-6 weeks....
Old Apr 18, 2013 | 07:20 PM
  #94
trymes's Avatar
I would stay right away from automatic chokes. Most people are trying to go back the other way! Your car should already have the cables for the manual choke, and there's nothing that works better.
Watch these videos, if you haven't already. Part 3 gives you a good idea of the complexity of the automatic choke, and why people avoid them.
Tom
Old Apr 19, 2013 | 12:03 AM
  #95
I think you have me sold, David from Everydayxj might have a rebuild kit for me, I'll keep it simple and cheap and just rebuild the Stromberg carbs.
Old Apr 19, 2013 | 05:15 PM
  #96
Well I got the wood trim/dash all removed from my 1985 XJ6 and getting it swapped with a brand new set from those good boys at Myrtle. One problem...errr I forgot to label the wires so when I go to reinstall the trim I am scrreeewwwweeeddd. Is there a picture diagram where the wires hook up to?
Old Apr 19, 2013 | 06:17 PM
  #97
Doug's Avatar
Uh....um..... I hate to sound like a party pooper but is there some reason we are not opening new threads here? Rather than just adding more and more entries?
This one is 95 posts long and has changed subject about a dozen times.
Old Apr 19, 2013 | 07:09 PM
  #98
I was going to use it as sort of a diary regarding me fixing up my Jags, it also helps me from getting confused if I want to search for a helpful tip...rather than search for various threads I create(ed) I can go right here. Mr. Party Pooper
Old Apr 22, 2013 | 08:13 AM
  #99
trymes's Avatar
PT54 (What's your name, anyway?): I know what you mean, but past experience has shown me that threads like this become more cumbersome than you expect, and actually make it harder to find the information you are looking for. More importantly, as time goes on, only those people (like me) who are already participating in the thread will chime in, as others just aren't likely to invest the time to read it all. This means you'll get fewer good opinions and ideas. In the end, more, shorter, well titled threads will get you the best results.
Either way, if you haven't seen this information on Stromberg Carburetors, you should take a look: TR250/TR6 Carbs Part I
Tom
Old Apr 27, 2013 | 08:06 AM
  #100
Ronan W's Avatar
Default 88 xj6
Hi, I am new to the jag scene. I have a 88 Jaguar XJ6 which will not start. the engine turns and there is spark but not fuel. We even put power to the petrol pump but would still not start. I was wondering could anyone advise me to where the fuel cut-off switch is on this model if there is one? Apart from that we have no clue what to try next. any help would be much appreciated.
