1984 XJ6 Question About The Headunit.
Old 12-24-2009, 05:05 PM
m0t0rm0uth's Avatar
To remove the current stereo, follow these instructions (from my Haynes manual for series 1, 2, and 3 XJ12c and XJS, but it should be the same for the XJ6):
The following operations must be regarded as typical only. Unless the radio or cassette player has been installed as standard or factory-fitted option, the type of equipment fitted and its location may vary according to the individual manufacturer's recommendations.
Disconnect the battery and then remove the knobs from the radio, heater, and air conditioner control levers. These usually simply pull off.
Remove the radio control spindle nuts and the escutcheon, then extract the screws from the front face of the radio which hold it to its mounting bracket.
Withdraw the radio unitl the antenna, power, and ground leads can be disconnected, then lift it slowly out.
Refitting is the reversal of removal.
Simply spoken, you have to pull the heater - A/C control knobs and the radio knobs off, first.
rusty37
04-05-2020 07:40 PM
pnwrs2000
01-15-2018 07:20 PM
carcycle
09-07-2015 04:14 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
pnwrs2000
09-03-2015 11:55 AM
Quick Reply: 1984 XJ6 Question About The Headunit.
