1984 xj6 smoking
Old Jun 28, 2015 | 07:28 AM
Doug's Avatar
Originally Posted by xj6kev
i took the vacuum pipe of the manifold that goes to a sensor on the fuel rail then to the fuel pressure regulator, she started rough but when i covered the pipe she ran better and didnt smoke as much.does that mean it could be the fuel pressure regulator is naff ???
That's the fuel temperature sensor. When the fuel hits xxx-degrees (157ºF I think...not sure) the sensor opens up and vents vacuum to atmosphere, thus increasing fuel pressure. This is to help during hard starts when vapor lock or fuel percolation might be an issue.
If the regulator sees higher vacuum, fuel pressure is decreased. If it sees lower (or zero) vacuum, fuel pressure is increased. Typically, higher pressure would worsen a rich running condition. If the pressure is significantly too high then it can actually cause a rich running condition.
I'm not sure where you 'covered the pipe'---before or after the fuel temp switch.
A fuel pressure test is the best way to check the regulator. One visual test, though, is to pull the vacuum hose off of the regulator nipple and see if any gasoline dribbles out. If it does, that's a bad regulator for sure. Not, though, that lack of dribbling gasoline does not prove that the regulator is good.
Old Jun 28, 2015 | 07:34 AM
Doug's Avatar
also the fuel pump is running all the time is that normal?
If you mean the pump runs whenever the key is turned 'on' then, no, that is not normal. If it does then somebody has monkeyed around with the circuit.
However, the pump should run with the key to 'start' and it should be running whenever the engine is running.
It's not like the pumps on some older carbureted cars where you hear the pump pumping...and then not pumping....and then running again....in response to fuel pressure.
Old Jun 28, 2015 | 07:40 AM
Doug's Avatar
Originally Posted by amaezing
doesn't the AFM control the air fuel mixture?
It's the primary player, yes.
(Well, actually, the ECU controls mixture, primarily in response to AFM readings)
Faults can occur, however, which cause over-fueling, that the AFM cannot do anything about.
Old Jun 28, 2015 | 12:59 PM
amaezing's Avatar
Yes thats normal.
Old Jun 30, 2015 | 06:32 AM
xj6kev's Avatar
the fuel pumps as soon as the key is turned and remains on all the time the engines running would that cause over fuelling? also theres no valve on the fuel rail to check pressure. is there another way to check pressure?
Old Jun 30, 2015 | 06:45 AM
Doug's Avatar
Not intended operation. There's a fault in the circuit, or someone has modified the circuit
That's OK
No, would not cause over fueling. It's a safety issue....but it won't cause any running problems
Locate the hose to the cold start injector and disconnect it from the fuel rail. Now use that nipple for your fuel pressure gauge
jjlu2
Jan 29, 2016 07:02 PM
Inspector
Oct 17, 2015 12:51 PM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
