1985 XJ6 Starter Motor Removal and Replacement
Old Jul 14, 2019 | 06:39 PM
Mark Bialzik's Avatar
Default 1985 XJ6 Starter Motor Removal and Replacement
I have ordered a replacement starter motor XK's in California. I have the Series III Service Manual that includes no diagrams. I would appreciate any advice to speed up the process and help me avoid blunders. Based on the info. in the manual, thank goodness this is not a V12.
MB
Wauwatosa, WI
Old Jul 14, 2019 | 07:18 PM
Doug's Avatar
It's pretty straightforward. Unbolt, bolt-on.
There are some transmission vent pipes alongside the starter. You'll have to loosen the hold-down clips and move the pipes aside.
The starter is heavy. If you're not really careful when you lift it away it can get away from you and break off the oil sending unit, which is located a couple inches forward. Use caution...or remove the sending unit first! Only takes a minute
Removing the battery will greatly ease access to the upper mounting bolt (LHD cars)
The mounting arrangement use a rather thick spacer, about .125" or so. Sometimes this spacer stays on the old starter. Make sure to be aware of it and transfer it to the new starter
That's all I can think of at the moment
Old Jul 15, 2019 | 06:39 PM
Thanks Doug.
MB, Wauwatosa, WI
Old Jul 16, 2019 | 02:12 AM
Originally Posted by Mark Bialzik
..... I would appreciate any advice to speed up the process and help me avoid blunders. .....
Mark,
I've moved your question from General Tech Help to XJ6 & XJ12 Series I, II & III forum. This is the place to post technical questions about your model.
Old Jul 16, 2019 | 10:02 AM
JagCad's Avatar
Lost the detailed post. Short version.
Use a cord around the starter, secured above as a back up and for control during the "R& R".
Carl
YYZ
Nov 4, 2017 12:05 PM
Gustafh
Jul 25, 2017 08:57 AM
Windle2706
Jun 4, 2016 07:28 PM
Lagonia
Apr 10, 2016 04:58 PM
Dec 22, 2009 10:38 PM
