1986 jaguar collant leak
Old Dec 6, 2013 | 10:34 PM
unique3114's Avatar
Default 1986 jaguar collant leak
I have a collant leak somewhere it smokes when engine isn't running. The temperature Gauge inside the vehicle stays at about 85 Celsius once warmed up,it hasn't gone above 90 though. Is it a hose or should I use radiator repair fluid? I was told I needed a water pump then someone else said it could be the radiator. It was making a knocking sound earlier today.I've been keeping up with the collant & radiator warning light isn't on
Old Dec 6, 2013 | 11:15 PM
Doug's Avatar
Have a repair shop pressure test the cooling system. In most cases an external leak can be found that way.
It could be as simple as a loose hose clamp.
BrentGardner
29
Dec 16, 2024 12:13 AM
Rutty
XJ40 ( XJ81 )
Jan 10, 2019 09:47 PM
rusty37
Jun 7, 2016 04:43 PM
thedugger1
Sep 24, 2015 05:32 PM
daro31
Aug 27, 2015 09:26 AM
