1987 XJ6 4.2 Gearbox problem!
Old Nov 19, 2010 | 08:50 PM
Wollarin's Avatar
Default 1987 XJ6 4.2 Gearbox problem!
The gearbox wont go into 1, 2 or D.. But goes into R without a problem.. What can be the problem?
Old Nov 19, 2010 | 10:03 PM
Doug's Avatar
Do you mean the gearshift physically won't allow movement into 1,2, and D? If so I'd suspect a broken or binding shift cable or other problem related to the shift cable...such as the underbody bracket the holds the cable being broken.
Or do you mean the transmission operates only in reverse...but won't move the car forward in 1,2, or D ? If that's the case I'd suspect low fluid and/or loose bands.
Old Nov 21, 2010 | 07:49 PM
Wollarin's Avatar
The transmission operates only in reverse... Won't move the car forward in 1,2, or D.. The tranny has been drained for oil and refilled.. So low oil isn't the problem..
Old Nov 22, 2010 | 12:06 AM
Doug's Avatar
Well, they don't last forever.
But....adjusting the bands will sometimes bring 'em back to life. If you wanna DIY I can provide info. It's isn't very hard to do....and it's free.
Old Nov 22, 2010 | 06:01 PM
Wollarin's Avatar
Originally Posted by espresso
Was the fluid replaced because of said problem? Or did the problem show up after the fluid change?
Tried to replace the fluid, because of the problem..
Old Nov 22, 2010 | 06:05 PM
Wollarin's Avatar
Well, that would be worth a shot.. Would be alot faster (read; cheaper) if it just needed some Band adjusting.. Well, beam me up Scottie
Old Nov 22, 2010 | 08:54 PM
Doug's Avatar
Here's some reading on band adjustment
http://www.jag-lovers.org/xjlovers/x...ansxadjust.htm
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
pnwrs2000
Sep 3, 2015 11:55 AM
