71 XJ6 tachometer not working
Old Aug 30, 2016 | 12:32 PM
rsq911's Avatar
Default 71 XJ6 tachometer not working
Hi everyone:
the tachometer is inoperative, and has been since we purchased the car (35k original miles).
The needle is pegged all the way to the right (redline), I do not know if this means anything. All the other gauges are working.
Any assistance would be appreciated, and thanks in advance!
Paul
Old Sep 3, 2016 | 08:05 PM
rsq911's Avatar
Bump?
Anyone?
Old Sep 3, 2016 | 08:26 PM
Doug's Avatar
My guess is a mechanical failure somewhere in the innards of the thing....that is, something simply broke....and that an instrument repair shop can fix things up.
Old Sep 4, 2016 | 09:53 AM
JagCad's Avatar
Or, a lessor guess.
Most rely on the make and break of the distributor to create a pulse, in turn converted to mechanical movement. Classic electro mechanical technology. As it is the ground leg that is make and break, I would suspect it is grounded all the time, not off and on ground...
Find the ground lead to the - post on the tach. Disconnect it. Fire the engine. If it drops to 0, I got it. If not, Doug's theorem is most likely.
Carl
Old Sep 5, 2016 | 11:43 AM
rsq911's Avatar
Thanks! I will check all wiring (at the tach too). Everything at the distributor and coil is connected, but I will try disconnecting and turn the car on to see what does or does not happen.
Will keep all posted.
CougCol
May 12, 2016 01:52 AM
Kief
Apr 26, 2016 10:29 AM
declipse91
Oct 3, 2007 11:35 AM
Jan 2, 2007 06:45 AM
