73 XJ6 Info
Old Mar 19, 2007 | 02:29 PM
Jose's Avatar
Default RE: 73 XJ6 Info
a 1973 XJ-6 is a Series 2 XJ-6. The Series 1 XJ-6 was made from 1968 to 1972 though there was some crossover-leftover into 1973. It depends on the car's Serial Number.
I'll post an XJ Production Chart later-gater. (assuming this site allows picture posting).
Old Mar 19, 2007 | 04:25 PM
bigdreams05's Avatar
Picture posting is allowed no problem.
Old Mar 26, 2007 | 09:52 PM
Jose's Avatar
depending on your location, I can refer you to some salvage yards where I get parts for myself. But Rotors can be had new from AutoZone, Car Quest, O'Reilly's, you name it, they're cheap, why buy used? Refuse to pay a lot just because it's a Jaguar. There's caliper repair/rebuild kits too. All rubbers can be had in Red Polyurethane if you want, not expensive. I'm assuming you bought the entire rear "Cage", right?
Old Mar 30, 2007 | 10:29 PM
davidboger's Avatar
For the record, a 73 is a Series 1 car. Has the same interrior, and body style as the rest of the Series 1 cars. The main difference is the front bumper was changed to include the rubber overeriders. Every other part is compatable.
Your gearing ratio is probably a 3:54, identified by a tag on the differential (46/13)
I recently helped someone acquire a Jaguar rear end to put into a Mustang. His wesite is at Dazecars.com. He is in the process of rebuilding it now, and has a new posting on JagLovers.org with a place to get all the rebuild parts for less than $400. Check it out......
Good luck
David
rusty37
Apr 5, 2020 07:40 PM
xjrjag
Aug 17, 2019 03:45 AM
42Ajd
Dec 30, 2015 09:45 AM
vinny jones
Oct 5, 2015 07:20 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
