82 xj6 ticks
Old Nov 28, 2012 | 10:49 PM
82jaguarxj6's Avatar
Default 82 xj6 ticks
so my 1982 jaguar xj6 ticks while running and doesnt go away, its pretty loud and is irratating me. any ideas? how would i go about fixing it?
Old Nov 29, 2012 | 12:33 AM
Doug's Avatar
I'm assuming you are talking about an engine noise?
Some ticking from the injectors and valve train is normal. If it's closer to a clacking than a ticking, you might have a tappet guide coming loose. Bad. You can check for this by pulling the cam covers and visually inspecting for the guides contacting the camshaft.
More details would be helpful, perhaps. :-)
Old Nov 29, 2012 | 12:59 PM
it is coming from the engine, it is more of a clack and is coming from inside the motor. i have also seafoamed the motor and it didnt do anything.
Old Nov 30, 2012 | 03:44 PM
Fraser Mitchell's Avatar
Have you checked for loose tappet guides ? These are a common problem, (although I never had them with my 1980 car)
Old Dec 1, 2012 | 01:45 PM
JagCad's Avatar
Better find out. could be easily fixed now. Or a harbinger of disaester on the way!!!
Use a long thin rod ar a mechanics stethoscope.
Old Dec 2, 2012 | 11:08 PM
how would i go about reseating the tappet guides if thst is it?
Old Dec 3, 2012 | 08:05 AM
Calhale's Avatar
Two things as suggested by my mechanic:
1. First remove the cam and 'tap down' the guide (a process I defer to the mechanics) if you find one that's loose.
2. Obtain a tappet stakedown kit and have it installed to prevent the problem 'popping up' in the future.
Old Dec 3, 2012 | 01:44 PM
link on tappet stakedown kit? its a very steady tick that gets faster the more i press the gas, does this sound like tappet guides?
Old Dec 3, 2012 | 01:57 PM
Calhale's Avatar
Jagbits (Jaguar stakedown kit XJ6) had them, I recall. Coventry might as well.
And yes, it matches what I understand the symptoms to be -- having never *had* the problem, I cannot say with certainty.
Old Dec 3, 2012 | 04:15 PM
the motor also has only 115kmiles on it but it sat for 5 years. Coventry West, Inc. - Online Store so this is what i need?
Old Dec 3, 2012 | 04:16 PM
it also sounds similar to this
Old Dec 3, 2012 | 04:41 PM
pulled of the cam cover off. there isnt any chips or markings on the guids or cam. what could it be?
Old Dec 4, 2012 | 01:39 PM
Calhale's Avatar
That's what you should buy, yes -- and consider it a 'preventative maintenance' kind of thing -- regardless of if it's the problem or not, it should be done pretty quickly.
Old Dec 4, 2012 | 04:03 PM
Have you checked the tappet clearances ? You mentioned the car stood for 5 years. You could have a bent inlet valve due to it being lazy coming back off the cam due to lack of oil on the guide. I had this happen to me after my car had stood for several years. It's a head-off job unfortunately. However this would affect the running of the car, but you don't say anything about this.
Old Dec 4, 2012 | 04:26 PM
the car also has a exhast leak. im kinda getting discouraged with this. its a nice car and would love too drive it.
Old Dec 4, 2012 | 04:33 PM
it has this sound from idling too under a load also. would a compression check give you guys a better idea?
Old Dec 5, 2012 | 05:56 PM
well im gonna do a full tune up too it and see if that helps. i will also be getting rid of the cat converter (where the exhaust leak is) and getting a new muffler. any suggestions? how do glasspacks sound on these?
Old Dec 11, 2012 | 03:02 PM
tjwiseman's Avatar
Glasspacks...... perhaps you would be better suited with a Honda civic
Old Dec 11, 2012 | 03:43 PM
NBCat's Avatar
Prior to modifying the vehicle by removing the catalysts, it might be wise to check with the local motor vehicle department for your state to determine if it is legal to do so. If the vehicle is subject to periodic emissions testing, it will fail with the catalytic converters removed.
The posting on this thread have given you good advice regarding the tappet 'stake down' kits available from several vendors. They are relatively simple to install and can prevent catastrophic engine failure if a broken piece of one of the exhaust tappets finds its way into the timing case.
If one of the valves has begun to stick, the cylinder head will need to be removed and decarbonised.
Old Dec 11, 2012 | 04:22 PM
the sound has almost comletly dissapeared after a tune up, and btw i went with magnaflow
