'83 fuel hose size?
Old May 2, 2019 | 07:38 PM
Cabel's Avatar
Default '83 fuel hose size?
Gents,
Anyone know the correct size fuel rated hose from the saddle tanks to the selector valve in the boot? it fits on a nub fitting on the bottom of each tank, then a short piece of hose, then an aluminum tube into the boot, then another longer section of hose to the valve. 1/2" seems to small and 5/8" too big. Thanks!
-Cabel
Old May 2, 2019 | 08:02 PM
Doug's Avatar
It's 1/2" as far as I know. That's what I've always used on the fittings that are actually in the boot. I don't recall using anything different on the nubs right at the tanks....but it's been a long day.
Others will chime in
Old May 3, 2019 | 04:48 AM
muttony's Avatar
It's 7/16. I have a text document with all the fuel hose sizes, locations and clamp numbers if you need it.
Old May 3, 2019 | 11:58 AM
Cabel's Avatar
Please! That will be one I will really use as most of my lines are in very poor shape.
Old May 3, 2019 | 12:19 PM
iramphal's Avatar
That chart with Hose/clamp sizes would be a great tool to have as I want to change everything also. Can it be posted?
Old May 3, 2019 | 12:22 PM
muttony's Avatar
I'll take a photo of it and post it when I get home from work tonight. I don't know if I wrote down the clamp sizes but I'll see if I can't scare up the sizes. I bought a box of assorteds and ended up running out because they're all like one weird size and Advance Auto near me didn't have any proper fuel hose clamps.
Old May 3, 2019 | 08:04 PM
muttony's Avatar
The Clamp SIzes I used most IIRC were 13-15mm mostly. Biggest were 15 -17 mm IIRC. Anything smaller than the 13-15mm and you will struggle to get them on. This is a compendium of what others wrote but what I used when replacing mine maybe amonth ago. Get extra 5/16".
Karl V
Feb 11, 2018 01:55 PM
kmarajh
Sep 15, 2017 05:38 AM
bazanaius
Apr 16, 2016 05:46 PM
FastKat
Feb 14, 2014 09:08 AM
Craig Schmidt
Oct 26, 2011 05:54 PM
