XJ6 s1 front caliper piston size and BMC size
Old Feb 10, 2018 | 02:04 PM
Karl V's Avatar
Default XJ6 s1 front caliper piston size and BMC size
Hello!
I wonder if anyone knows the piston size in the 3 piston front calipers for the early xj6 and also what size the master brake cylider has?
Thanks!
Old Feb 10, 2018 | 04:45 PM
Karl V's Avatar
Or the four piston caliper size if it has the same rear caliper.
I´m trying to find what balance the xj6 hade between front and rear brakes.
Old Feb 11, 2018 | 01:55 PM
icsamerica's Avatar
I know the Series II. The, 4 piston fronts... each piston is 48mm or 1.89 inches. The rear 2 pistons are 43mm or 1.69 inches.
I would assume the rears stayed the same from Series I to II as the Series II increased in weight. Most of that additional weight is front-ward. USA bumpers, A/C compressor and related components, emissions equipment and the additional structure behind the dash were all far forward of the cars center.
So on a Series II the piston area is 11.22 sq/in front and 4.48 sq/in for the rear.
With smaller rotors out back than in front as well. So the brake bias is a bit over 60% forward biased.
The m/c bore is 15/16 all the way through.
User 070620
Jul 23, 2014 07:53 AM
jamStypeR
17
May 26, 2012 06:44 AM
Racer343
Sep 25, 2011 07:57 PM
steve0z535
Jun 30, 2010 08:54 PM
mandoman
Oct 14, 2008 05:38 PM
