84 XJ6 4.2 problems when warm
Old Feb 27, 2016 | 03:44 PM
Cjkcue's Avatar
Default 84 XJ6 4.2 problems when warm
Hello,
I just bought an 84 xj6 with 59k original miles. The car starts up fine and will idle and can rev it up for about 5 minutes. After that, the car struggles to idle and will cut off. The car will not start again while warm. Even with a shot of starting fluid.
I read that sometimes it could be the ballast resistor but that was removed by the previous owner.
Any help would be great! Thanks again.
Old Feb 27, 2016 | 10:07 PM
Doug's Avatar
Originally Posted by Cjkcue
Hello,
Which suggests, but does not verify, that you are lacking spark. I'd begin by checking for spark... but a few other quickie things:
- do the injectors click when you are trying to start?
- there should be a black/white wire running aft along the water rail, from the coil "-" post. Is it in good condition?
- unplug the coolant temp sensor connector and use a paper clip to jump the two terminals inside the boot. Any change in the problem?
- any black smoke from the exhaust, or smell of fuel. or any reason to think it is flooding out?
One less thing to worry about
Old Feb 27, 2016 | 10:29 PM
Cjkcue's Avatar
- there should be a black/white wire running aft along the water rail, from the coil "-" post. s it in good condition?
Thank you Doug! I will check/try these and report back.
Old Feb 28, 2016 | 04:41 PM
Cjkcue's Avatar
So I figured it out. Bad coil.
Now I have a new problem. I am not getting fuel to the fuel pump. The pump is running. I took the hose off the inlet of the fuel filter and turned the motor over but no fuel. Is there another filter I need to change inside of the tank??
calteg
Mar 7, 2016 03:12 PM
veeracer
E type ( XK-E )
Mar 3, 2016 02:28 PM
michaelodonnell123
Feb 25, 2016 01:14 PM
1983turbojaguarxj6
Feb 24, 2016 04:50 PM
