85 XJ6 (S3) Headlight Fuse
Old Feb 25, 2009 | 08:52 AM
Doug's Avatar
Low beams use 20 amp, high beams 35 amp.
The forward-most fuse is a 15 amp for the aux cooling fan. Then you should have 20-35-20-35 for right low beam, right high beam, left low beam, left high beam, respectively.
If you're in the USA and/or don't have correct British/Lucas replacments use this to convert to USA style fuse ratings:
http://www.jag-lovers.org/xjlovers/x...conversion.htm
Old Feb 25, 2009 | 08:56 AM
Jose's Avatar
you can get the correct fuses at any Jaguar dealer Parts Dept.
do you not have the Owner's Handbook in the glove box? All the fuses and bulbs are listed there.
The picture is fine, the vertical/standing fuse in the picture is a spare, there's room for two spares.
Jose
eurotire
Sep 18, 2015 07:27 AM
1100me
Aug 28, 2015 09:48 PM
dixie1351
Jun 17, 2009 01:16 PM
Tomcat
May 14, 2008 08:09 PM
