'85 XJ6 - What is this?
Old May 12, 2015 | 04:55 PM
Mike Beda's Avatar
Default '85 XJ6 - What is this?
Hi Folks,
What is this thing here (picture attached)?
I'm trying to find a suspected vacuum leak and this connects to a pipe that looks like it connects to the throttle body. I'm hoping it is a coolant pipe and not another vacuum line.
Thanks,
-mB
Old May 12, 2015 | 05:02 PM
Jose's Avatar
that is the engine breather cap
Old May 12, 2015 | 08:06 PM
Mike Beda's Avatar
Thanks, Jose.
So there's another potential vacuum leak. I notice the pipe tees off and the branch also has some sort of switch and then disappears through the right "wing" (I would say fender but I'm trying to think British).
-mB
Old May 12, 2015 | 11:12 PM
Doug's Avatar
The switch is a purge valve. It opens to draw in fuel vapors from the vapor canister in the fenderwell
Old May 13, 2015 | 04:21 AM
Jose's Avatar
Mike,
you welcome, that is not a vacuum source, it's a fuel vapor recovery system, like the PCV check valve system; The purge valve or "switch" allows fuel vapors to be routed into the engine to be burnt during combustion.
trickeyM
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
baskervillema
Oct 1, 2015 06:43 PM
dansxj6
Sep 28, 2015 08:02 AM
42Ajd
Sep 26, 2015 07:04 PM
