'86 Crank-Hit-Die Update
Old May 22, 2013 | 08:02 PM
Wascator's Avatar
Default '86 Crank-Hit-Die Update
While checking out the fuel injection equipment, looking for air leaks, etc., and general tidying under-bonnet, I found a short wire connecting a ballast resistor mounted next to the coil, to a female spade connector at the front-right side of the engine. The wire was yellow, and had a crimped-on male spade terminal, non-OEM, and the wire pulled right out of the terminal. Aha!
I hate crimp terminals. All they are good for is trouble later on.
Wonder where I can get the factory male spade terminal? Can I buy one, or is it a salvage item?
Also cleaned and inspected all the grounds I could find at the front of the car. I am about to change the fuel filter; change brake fluid, et al. The fun never ends!
Old May 22, 2013 | 09:35 PM
JagCad's Avatar
Yeah, I detest that crimp on stuff. I usually strip off the soft stfuu and solder the thing to the wire. A couple of layers of shrink tubing neatens the job and provides the needed insulation.
I even reuse solder fittings. Sweat out the solder and stub wire. Or splice the remaining stub wire to my wire. in each case, a layer or two of heat shrink tubing and all is neat, tidy and long lasting.
I am not very good at tossing things away, I usually see a repurpose possibility.
My old dud microwave yielded it's case as a nice source of sheet metal. Not good steel and welds poorly at best. But, cuts and bends nicely. I repaired the broken front splash pan in my daughter's VW Passatt with it and pop rivets. I needed to bend in some shapes to make it fit nicely.
oldjaglover
Dec 25, 2024 04:33 PM
spdracer
Oct 1, 2015 01:43 AM
aadjei
Sep 25, 2015 03:07 PM
