'86 Vandan Plas XJ6 no start
Old Oct 4, 2024 | 05:44 PM
Doug's Avatar
Originally Posted by packetthrower
David,
With all original bits put back in. I have a running car. This car did not run when using a jumper before but now it does with the original coil and ignition module. It sputtering but it started and is running.
What would be your suggestion?
I see yours is one of the ones made with a ballast resistor.
Did you run your jumper wire to the resistor or directly to the coil "+" post? Just wondering.
Sometimes the resistors give trouble.
Old Oct 4, 2024 | 07:30 PM
packetthrower's Avatar
Doug,
Yes, mine did come with that ballast resistor. I have yet to try starting the car without it. I went directly to the ignition Coil Positive post, pinched the jumper wire under the ballast resistor, and tightened it.
Old Oct 4, 2024 | 08:02 PM
David84XJ6's Avatar
Good catch Doug, I missed that.
The New Rock Auto ignition coil should replace both the old ignition coil and it's ballast resistor. If you left the resister in the electrical loop, I suspect there would not be enough current for a spark. A newly manufactured Ignition coil of .9 ohms would not require a resister, the older designed .9 ohm coils needed the ballast resister.
Rgds
David
ka1thm
Feb 20, 2024 12:41 PM
Joexkr2001
US Northeast
Sep 17, 2022 07:38 AM
c2i22
Jul 18, 2011 07:15 PM
Craig McNulty
May 10, 2009 10:32 AM
