'86 XJ6 Crank-Hit-Die Phase II
Old May 30, 2013 | 08:52 PM
Wascator's Avatar
Default '86 XJ6 Crank-Hit-Die Phase II
I got the new coil installed today; this along with the new GM module in the Lucas "Magic $800 Box" I hoped would cure the C-H-D Syndrome. Well, she started right up, and idled very nicely. I decided I would go to town and get some gas: 5 miles. Soon as I put it in reverse, it died. It started right up and off I went. When I stopped at the next intersection (almost there) it died at the intersection. This is the first time I recall this; formerly it would not restart after a drive without multiple tries with the C-H-D.
This time it seems to restart much more easily, and with fewer tries. Also, adding a little throttle seems to help it restart, where it never seemed to help before. I don't know where I am going with this next: maybe the idle air valve? Also, I have checked every ground I could find, but the one on the ECU in the trunk.
The car just runs so good when it runs: no stumble, etc, that it is a little perplexing that it keeps dying.
Also I noticed the coil I removed had a label on the underside, with a date of 2003 on it, so it was not the original coil. It has a chip on the plastic + tower but I don't know if this would cause trouble.
I plan to change the coolant tomorrow: I bought 2 gallons of Zerex G-05: the label on the back indicated it was approved for Jaguars of my car's vintage; i.e. older ones, so I decided to use it rather than the "fits all cars" Prestone I already have.
Sign me "marching on"
Old May 30, 2013 | 11:28 PM
Doug's Avatar
Perhaps this has already been mentioned but is the throttle body clean and the throttle blade set at the proper .002" gap?
What's your idle speed?
A thread from a couple weeks ago covered something similar. Might want to read some of the replies. I think it was titled "Stalls in gear" or "Stalls with A/C On" or similar
Old May 31, 2013 | 07:31 AM
Wascator's Avatar
I did check the throttle body earlier with a feeler; the gap seemed about right. I wiped out what I could with the throttle plate held open and it wasn't particularly dirty, but not white glove clean either. Should I remove it and dunk it in cleaner?
The idle speed seems a little high at just over 1000; I don't know if someone adjusted it previously in trying to get it to stop dying, or what. I did notice that, after I installed the coil, when I started it, that is the first time I noticed it idle at just under 1000, according to the dash tach. When I garaged it that evening it was just over 1000, though. I am still looking for air leaks after I found the vacuum advance hose rotten on the end. I am reviewing the previous posts regarding this topic as well; I will be able to go in deeper this weekend, than I can on evenings after work.
Thanks!
Old May 31, 2013 | 09:55 AM
Doug's Avatar
If it was idling at 600-700 I was gonna suggest bumping it up a bit....as these engines are weak at low idle.... but 1000 rpm is plenty.
Throttle body does not have to be white glove clean. So long as it isn't outright gunked-up it should be OK and you can focus elsewhere.
Here's what I would do next. Run a jumper wire from the battery "+" post to the coil "+" post. Start engine, drive car. See if anything changes.
Carefully inspect the wiring/connection at the coolant temp sensor. Repair if it looks flakey. If the connector looks OK, use a thin paperclip to jump the terminals inside the connector. Drive car, see if anything changes. Do this on an already warmed-up engine.
Do a good, careful check/clean/repair/tighten routine on wiring/grounds/connectors related to the firewall relays, coil, air flow meter, etc.
trickeyM
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
baskervillema
Oct 1, 2015 06:43 PM
dansxj6
Sep 28, 2015 08:02 AM
