air flow meter
Old Sep 21, 2014 | 05:23 PM
amaezing's Avatar
Default air flow meter
My air flow meter is sticking I think. Went thru all the fuel system and tanks. getting good flow and pressure. After I stop a few times I loose pressure or power. started messing with the flapper on the air flow meter and noticed that it is a bit sticky. Im not positive this is the problem but fairly sure. Its really hard to tell but as I was messing with it as it was running it did the same thing so I'm asumming that its the problem. Any one else come accross this before?
BTW it is a 1985 XJ6 Vanden Plas.
Old Sep 21, 2014 | 05:52 PM
Doug's Avatar
Well, the AFM has two main functions:
1) An internal switch activates the fuel pump circuit when the flapper is opened. The fuel pump, of course, provides pressurized fuel to the injectors
2) The Air Flow Meter sends a signal to the ECU. The signal varies according amount/degree that the flap is opened. The ECU uses this signal to decide long low the fuel injectors should stay open.
The flapper should not feel sticky. There might be a mechanical problem inside, or perhaps the resistor track is very badly worn
In any case if fussing about with the AFM causes an engien stall it's a fair bet that you've found the problem. Do check electrical connectors first.
Used AFMs are not expensive. I just sold one on Ebay for something like $25
Old Sep 21, 2014 | 06:24 PM
amaezing's Avatar
Smile
Doug,
Thank you, I really appreciate the info. I am going to try and put some lube on it since it seams to be sticking because it feels like it's just dry and dragging but I will check the electrical connectors as well.
Thanks again, I am greatful.
Old Sep 21, 2014 | 06:57 PM
amaezing's Avatar
Fixed!!!! I put a tiny shot of PB blaster on it and it's fixed. I love this car!!!
Old Sep 21, 2014 | 07:11 PM
Doug's Avatar
Far out
Old Sep 25, 2014 | 02:05 PM
amaezing's Avatar
I think the meter is still wacky. Runs great now but now it's a bit hard to start. Does this now since I messed with the meter, but have to crank it over once or twice then it will fire up as before it would just fire up right off the bat.
FrickenJag
Jun 16, 2025 02:15 PM
Lannyl81
Sep 19, 2015 08:07 PM
explorer364
Sep 14, 2015 07:43 PM
rachelstr
Sep 3, 2015 12:59 PM
