Aircon compressor removal
Old Feb 23, 2016 | 06:51 AM
NathanDD6's Avatar
Default Aircon compressor removal
Hi all
I'm wanting to remove the aircon for better access to the spark plugs... Is this doable? Do I need to bleed/drain anything? Anything to watch out for?
Many thanks.
Old Feb 23, 2016 | 07:02 AM
Doug's Avatar
Not remove, just shift aside a bit.
There are four bolts holding the compressor. Two front, two rear. The fronts are often buried under caked-on gunk. The rears require that the cruise control servo be partially removed: unbolted a shifted aside
With the four bolts removed just tilt the rear of the compressor upward a few inches to give access to the front plugs. I use s small block of wood as a prop to hold it in place
Old Feb 23, 2016 | 07:07 AM
NathanDD6's Avatar
Brilliant, thanks Doug.
mitcharon
Mar 20, 2016 11:57 AM
Russell Routt
Feb 24, 2016 05:34 PM
DavidXK
Feb 17, 2016 09:20 AM
rsmartin
Feb 1, 2016 11:29 PM
