AJ6 engine short power loss/jerk when driving.
Old Aug 31, 2016 | 11:24 AM
NJ2003XJ8's Avatar
Default AJ6 engine short power loss/jerk when driving.
Hello,
I am here from XJS forum, but very few XJS with AJ6 3.6 engine there... I think many of XJ6 have the same AJ6 engine so hopefully you will let me in on some AJ6 secrets :-)
My problem is that when I drive and take foot off gas and then give it some gas again car looses power for a split second before starting to accelerate. It makes unpleasant 'jerk' in the drivetrain, pretty annoying... just to clarify, I am not talking about totally 'of gas - engine break - give gas sequence', under normal driving when I 'ease' throttle to the point car just rolls and when I give some back for split second it kinda cuts-off(with engine breaking for that split second) and then accelerates .
I have to admit that I 'screwed in' the throttle stopper bolt a little to bring idle a little down. perhaps I screwed it too far? Is there a right procedure how to tune throttle mechanism? I see there are few adjustments beside the stopper bolt that can be done. (there are also two bolts that allow to rotate top part of assembly)
Any ideas where I should look for the problem?
Thank you.
Old Aug 31, 2016 | 06:30 PM
Tar's Avatar
Tar
NJ,
The AJ6 engine was never installed in Series I, II and III XJ6's and '12's, the subject of this forum, with the exception of a few stalwart souls who have done conversions to that engine.
However, the following generation of XJ which is known as XJ40 used the AJ6 at inception, so you should find plenty of information and suggestions in that forum.
Best of luck to you. It sounds as if an adjustment or two might set you right.
Andrew.
Old Aug 31, 2016 | 06:51 PM
NJ2003XJ8's Avatar
Oh, thank you for pointing in right direction..
I consulted google...
Vehicles using the 3.6 were:
1984–1989 Jaguar XJ-S
1986–1989 Jaguar XJ6
1986–1989 Jaguar XJ6 Sovereign
1986–1989 Daimler
and looked for a forum with XJ6 in it's name :-)
Old Aug 31, 2016 | 07:57 PM
Tar's Avatar
Tar
Yes, those are correct. But it can be confusing: here in the States, 1986 and 1987 were the last two years of the "old" XJ6 (series 3); the AJ6 3.6 was introduced here, in the XJ40 XJ6, for model year 1988.
Andrew.
34by151
May 6, 2024 12:20 PM
LnrB
Feb 27, 2017 02:48 PM
frostee
Apr 21, 2016 08:50 PM
orangeblossom
Mar 31, 2016 08:14 PM
jantech
Mar 25, 2016 11:26 AM
