Anyone using REDTEK in AC?
Old Jun 4, 2018 | 12:11 PM
ChuckR's Avatar
Default Anyone using REDTEK in AC?
G'Day
I am thinking of using this REDTEK product RED TEK in my 87 Vanden Plas 12 cyl. Seems more reliable than 134a and others, any comments appreciated.
Chuck
Old Jun 4, 2018 | 06:35 PM
icsamerica's Avatar
Redtek 12a is basically propane so if you're ok driving with a BBQ tank on your grill this stuff is for you. I wouldn't do it and getting R134 to work well enough isnt that hard.
You basically have to do 2 things, adjust you expansion valve and add a pusher fan in front of the condenser that runs when the compressor is on. You dont "have" to adjust the expansion valve but it would help.
If you want to get fancy wire the fan to a standard R134a pressure sensor or add a thermostic switch in the condensor so that when the condensor get hot the fan comes on.
Old Jun 11, 2018 | 09:16 PM
ChuckR's Avatar
Default Follow-up on REDTEK 12a AC Recharge
So for info, bought the RedTek kit at our local Canadian Tire Auto Parts store and recharged IAW directions on the box. AC temperature high was 17 deg Celius before recharge, now 3 deg Celius, 38 PSI indicated on gauge from kit. Adapter in kit to convert low side port from R12 to R12a RedTek fit well and used some thread tape just to be sure. Will use the oil analyzer provided in kit in a day or so and check results. For info the low pressure port is the brass coloured line on the left (drivers side LHD) exiting out of the rear of the compressor a GM Harrison. Will advise if there are any problems over the summer months.
ChuckR
ndy4eva
Audio/Visual Electronics
Jan 11, 2010 09:45 AM
tarheel72
Feb 28, 2008 05:51 PM
