Back to Front > Left or Right
Old Mar 26, 2021 | 12:41 AM
adenshillito's Avatar
Default Back to Front > Left or Right
Here's a quick one, I lost track of these being left or right side, and the plugs too, they have an angled rubber surround, is it angled to the outer side of the car or inner, luckily the blocks are marked with TOP but no ref to side/angle. really should make more notes .....and take more pictures.
left > right > left ?? pins are diff in the middle so must be specific to a side...
thick edge to the outside or nearer engine?
which is the left side or and right side ... must make better notes.
Old Mar 26, 2021 | 01:52 AM
Greg in France's Avatar
The sockets are not identical, if you look carefully. If the loom is in the car still, you can match the pins with the loom plugs.
Old Mar 26, 2021 | 06:02 AM
Yeap, central blocks of pin are inverted top to bottom on one block, i'll look at the plugs tomorrow. two plugs at drivers side and three at passenger side.
LongJohn
Aug 29, 2023 01:27 PM
Om28v
Oct 5, 2019 04:26 AM
Isoruku
Sights N Sounds
Nov 13, 2018 09:56 AM
Pie944
Jul 6, 2018 10:30 AM
gtjoey
E type ( XK-E )
May 20, 2018 04:59 PM
