Backfiring Problem
Old Jul 20, 2017 | 11:52 AM
Autobot1996's Avatar
Default Backfiring Problem
Hello, My 1982 XJ6 is having some troubles. At some times, it will start normally and I'll drive. However, after a while the RPM will drop and when I press the accelerator it is hesitant and will backfire a few times and eventually return to a normal operation. On some occasions, upon starting the vehicle, it has low RPM and and when I press the accelerator it'l backfire. Anyone have any insight on the matter?
Old Jul 20, 2017 | 02:36 PM
Dr Phill's Avatar
Back firing is normally due to incorrect ignition timing or over fuelling. The fact that it seems to fluctuate may be caused by a failed distributor base plate bearing. Its a long shot but worth checking.
Old Jul 20, 2017 | 03:01 PM
new mexico's Avatar
You have a lean mixture.
Have the injectors ever been replaced. I would start with their replacement
and at the same time replace the fuel hoses.
It should make a difference in performance.
Walter
Old Jul 20, 2017 | 07:03 PM
Robert Wilkinson's Avatar
By "backfire" do you mean coughing up through the intake (often a lean problem or timing) or blasts through the exhaust (often a rich problem).
