Battery recommendations
Old Nov 30, 2023 | 05:38 AM
brinny's Avatar
Default Battery recommendations
Hi all, can anyone recommend a battery for a 73 series 2. Or tell what code number I need. Many thanks in advance.
Old Nov 30, 2023 | 05:56 AM
Jose's Avatar
the highest CCA (Cold Cranking Amps) you can fit in the available space.
I use the ACDelco Group 78VPG but my '84 has the side terminals, so you'll need to find one with the correct type terminals or "poles" in the correct position for the cables.
Old Dec 2, 2023 | 03:27 PM
xjtom's Avatar
just bought a new one for my S2, 650 CCA (or 640) is a good size, you can get a 720 CCA but finding the terminals for a 720 the right way ain't so easy, i use the top mount terminals with the pos/ on the engine side & both terminals @ front of battery not at fire wall side.....if you don't drive often - i fitted an isolator switch to the pos/ side - saves the battery 'cause i don't really care if the clock & radio aren't on standby.
recorder72
Aug 23, 2021 10:49 AM
jammer
Mark V - X 420G
Oct 12, 2018 11:31 AM
ebrand
E type ( XK-E )
Oct 29, 2015 09:51 AM
paddyh
22
Jul 12, 2014 10:35 AM
SV8Predator
Apr 12, 2009 04:26 PM
