Best u-joint source?
Old Mar 11, 2016 | 12:22 PM
JigJag's Avatar
Default Best u-joint source?
Hello,
I'm the proud new owner of a 1982 XJ6. Amazingly I purchased this Jag not running and, after an ignition switch repair, I'm now driving this all-original 82 daily. Ok, it's only two days but still!
I have what appears to be an early failure stage u-joint on the outer passenger side.
What brand is your recommendation for this part? Best source?
Thanks in advance!
Old Mar 11, 2016 | 01:54 PM
Doug's Avatar
I like Dana-Spicer UJs when I can find 'em....but usually I have to order them. Nobody in my areas carries them on the shelf.....at least not under the "Dana-Spicer" label.
I've also had perfectly good results with whatever NAPA sells.
Old Mar 11, 2016 | 05:10 PM
davidboger's Avatar
Hey Jig Jag...
I may have a few on hand... And if not, I have a ton of other stuff for your car...
Best part, I'm only about 30 miles North of Charlotte (near Concord)...
Check out my site, or give me a call sometime... (704-796-9902)..
I'd be glad to talk to you about your XJ...
David
shop.everydayxj.com
Old Mar 14, 2016 | 08:47 AM
lickahotskillet's Avatar
Default Best U-joint source
Northern Drivetrain, LLC
For Spicer U-Joints, I used these folks for my '77 XJ12L u-joints.
I went with "no zerks". U-joints without zerks are stronger. Spicer u-joints are pre-grease with a new synthetic grease. Instructions indicate - do not add grease.
Grease does not get sprayed out of the u-joints from over greasing.
Old Mar 14, 2016 | 10:49 AM
JigJag's Avatar
Originally Posted by davidboger
Hey Jig Jag...
David
shop.everydayxj.com
David,
This is fantastic! I'm glad to see there's a Jag parts source so close by!
I definitely want to come by and check out your operation. I think the U will hold out for a trip up to Concord. In the meantime I'll give you a call. I'd love a chat with someone more knowledgeable!
let me know if you have one available! I'd rather not source from NAPA unless necessary.
Thanks so much!
Paul
Old Mar 14, 2016 | 02:02 PM
tommie_jag's Avatar
Hello,
I have to replace the u-joints on my series 1 jag too.
Do someone know which type of Dana-Spicer I need?
Or maybe the type of GKN joints?
Greetz Tom
From the Netherlands
IndelXK8
Mar 27, 2016 08:33 PM
TexMurphy
Mar 20, 2016 08:45 PM
Busa
56
Mar 14, 2016 03:43 AM
XKR2000
Mar 13, 2016 06:52 PM
geo2005_XK8
Mar 11, 2016 03:09 PM
